Scangauge or AE?
Old Jan 31, 2010 | 07:10 AM
  #61
gbroehl1's Avatar
gbroehl1
I posted up some more information on the PSN thread. Thanks.
Old Feb 1, 2010 | 09:45 AM
  #62
superduty4x4's Avatar
superduty4x4
AE will be here Wednesday... might add the Scangauge when the taxes come in
Old Feb 3, 2010 | 01:53 PM
  #63
superduty4x4
UPS says there is a box sitting on the porch waiting for me... come on 5:00!
Old Jun 3, 2010 | 07:23 PM
  #64
overthehillbill's Avatar
overthehillbill
Hello All:
I got the Scangauge ll today and plugged everything in, entered the TFT code and was very pleased. I shut everything off and routed the cable and when I plugged it back in
it just stayed in the "connecting" mode. I did try to force the PWM.
Any help is appreciated. Bill
Old Nov 10, 2010 | 02:52 PM
  #65
Bowie's Avatar
Bowie
Can the DD change the tires size on our trucks?
AKA what does the DD do that the AE cannot. Besides display stuff instantly.
Old Nov 10, 2010 | 03:00 PM
  #66
gbroehl1's Avatar
gbroehl1
The DD can not change tire size (that I am aware of) and can not run the additional tests that AE can run. AE still has its purpose, but I am happy enough to borrow someone's for that occasional need.
Old Mar 1, 2012 | 01:04 PM
  #67
MikeSDK's Avatar
MikeSDK
Originally Posted by Izzy351
That's true -- and is why I have dedicated gauges for fast acting stuff. Bottom line is if you want to see everything you need on one gauge, this is it. Things like Pyro, Boost, Fuel Pressure, etc, need dedicated gauges. I watch battery V & EOT, full time until it's warm. Then I switch to something else if I want. I don't always need to see HPOP pressure, DC, etc, but I do look at it now & then. When I swapped injectors, it was VERY handy to see where the HPOP pressure was as the air was purged. As it slowly built up, the second it got to 500psi, the truck started. Took 2 or 3 5-10 second cranks to get it there.
Can you tell me what parameters you are looking at to monitor HPOP pressure? I looked on their website, and didn't see it mentioned specifically-
Thanks!
Old Mar 1, 2012 | 01:13 PM
  #68
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
Thanks!
mike check out your other thread i posted up the pic for you....icp duty cycle % and icp pressure is what you read to see how the hpop is doing.....
Old Mar 1, 2012 | 01:15 PM
  #69
indyF-350psd
and the answer to the thread question is BOTH! the scan gauge is good for on the fly and quick stuff but AE is going to be more in depth and complete for diagnosing stuff.....
Old Mar 1, 2012 | 01:31 PM
  #70
SARDiverDan's Avatar
SARDiverDan
Are we using the term “scangauge” in a generic sense or the actual scangauge product? In referring to the product they make three models ScanGauge II, ScanGauge D, and ScanGauge E which one is the best all-around one to have? I would assume SGII or is this entirely different?
Old Mar 1, 2012 | 06:01 PM
  #71
honeydew's Avatar
honeydew
SGII is better than the E for monitoring parameters. D is new and looks interesting and says it is designed for Diesel pushers and OTR trucks.
Regarding earlier post- SGII will show HPOP and ICP pressure but won't display both simultaneously. If you try that HPOP shows no data.
Old Mar 1, 2012 | 06:22 PM
  #72
SARDiverDan
Thanks for the info. I went ahead and picked up a SGII at AutoZone when I went to the bank and mounted it up in the truck right above my headlight switch. I know they have a list of gauges to choose from but I also know that not all of them will work. Is there a reliable list out there as to what exact functions will work and which ones will not so I don’t add gauges that will just read zero the whole time and I end up cycling through non-working ones to see those that work? I still plan on getting other gauges from Riffraff but this little item will come in handy.
Old Mar 1, 2012 | 06:33 PM
  #73
honeydew's Avatar
honeydew
This link has the x-gauge commands specific to the 7.3L and generic to Ford: Ford Specific XGauges : Linear Logic : Home of the ScanGauge
Most seem to work, EBP gives what seems to be inaccurate readings on my truck. The ones I look at regularly and am confident that work are: EOT, IPR%, ICP, HPOP. HPOP is not on this list. Either the codes were on an earlier version or on a thread somewhere.
A standard x-gauge from the manual I sometimes look at is current MPG (MPC). MPG is only close to accurate if you follow the calibration procedure and the calibration goes out the window if you switch tunes.
I have not programmed in the MAT because the standard IAT seems accurate. Probably worth doing a comparison. This data should be pulled from the MAP sensor.
Boost and tranny temp seem accurate but are redundant with regular gauges.
There are probably others worth experimenting with.
Old Mar 1, 2012 | 07:21 PM
  #74
SARDiverDan
I will play with it this weekend and see what I can load on it and I would assume I could delete the ones that don’t work. I selected the dim light for the display but I will have to see if I have a color choice. I have so many items in the truck that give off light that if I don’t get close to the same color as the other stuff it would look like Christmas in there at night.
Old Mar 1, 2012 | 07:41 PM
  #75
honeydew's Avatar
honeydew
Yeah you can delete them. You can make the screen green to match pretty well.
I had mine mounted below the headlight switch for a long time but got a blend mount for Christmas. It's real nice having SGII just above the rearview.
Amazon.com: BlendMount Designed for ScanGauge II: Automotive
