Compression question with head gaskets??
Old Jan 26, 2010 | 10:34 PM
pbear6969's Avatar
pbear6969
It's been a while since I have been on here and you've helped me in the past so here I am again. Got a question about compression ratio pertaining to Head Gaskets. I have a 410 motor and it spark knocks badly if I don't run a 60/40 mix 93/110 octane gas. We have played with the timing and can't get it to run on pump gas for nothing. I had everything figured up right until the machine shop resurfaced my heads and took more off them then expected and now it knocks. I used the Mr. Gasket .038 head gaskets. Would it make a noticeable difference if I went to a .042 gasket? Also could the timing being set lower be causing it to bog down in 2nd gear under heavy acceleration? Thanks for any help.... Josh
Old Jan 29, 2010 | 11:31 PM
85e150's Avatar
85e150
I don't think that difference will do much. Enter your variables here:
RSR Static Compression Ratio Calculator
I ran one set of numbers and it was less than half a point.
Old Jan 31, 2010 | 06:37 PM
fordeverpower's Avatar
fordeverpower
the gaskets will do nothing, as for 2nd gear it should be sluggish in all gears if the timing is backed off. May be pinging on accel in 2nd gear.
Old Feb 1, 2010 | 10:43 AM
pbear6969's Avatar
pbear6969
Guess I basically got two options then. Either turn the timing up and have to run racing gas or pull the heads off and get some different ones... Either way it's going to be expensive... errr Well guess I got three options. Could pull the pistons and put some lower comp pistons in it.
Old Feb 1, 2010 | 11:04 AM
Moto Mel's Avatar
Moto Mel
A 4th option would be to remove the heads and cc the chambers and then cc the area between the piston heads and the block deck. Find out what you actually have and then what you need in head gasket thickness to get the compression where you want it. Then do an online search for copper head gaskets. They are avaiable in just about any thickness. There is a company in the Chicago suburbs that make head gaskets and stock them for many of the popular engines. There are several other companys out there also.
Keep trying and let us know what you do to cure the problem. In reality the shop should replace the heads with the exact same ones because it's their screw up.
Old Feb 1, 2010 | 11:09 AM
Argess's Avatar
Argess
Some questions:
1/ What's your timing at idle with vacuum advance disconnected?
2/ Was your vacuum advance connected properly after the engine work? Easy to get it hooked to manifold when it needs ported, or vice-versa.
3/ Just exaclty how much did the Machine Shop take off? Usually it's only a skim, so maybe the problem lies elsewhere?
4/ Standard or manual transmission? (I know you said 2nd gear, but that could be an automatic)
5/ Do you happen to know the max spark advance? I know you said you tried it all over, but don't forget, increasing advance to get the bottom end to perform, may make the higher rpm range knock unless you limit the dist advance.
6/ Stock camshaft or performance since rebuild?, or in other words, did you do anything that might require different ignition timing?
The more you can let us know, the more chance of some one here knowing what's wrong. You are making the same mistake I make when posting a problem....you are leading us towards a CR problem when in fact it may not be related at all.....or it might.....LOL. So all facts need to be adressed.
Old Feb 1, 2010 | 11:19 AM
pbear6969's Avatar
pbear6969
Well that's a lot of questions and off the top of my head I can't answer all of them. lol I sent the dizzy to a racing shop and they set it up to be full advanced at 2800 rpm. he told me not to run the vac advance. It has the Petronix 2 conversion with MSD coil and ignition box if that matters. The timing question is something I will have to go check again. We were getting weird readings from it. IF I remember right it said I had like 32 degrees of timing at idle and moved up to around 50 at 2500+/-. The machine shop didn't take off much but we had it figured for just the right amount of quence with those gaskets, or so I thought. It's an automatic C6, with 3000 stall, heads were ported and polished and matched to the headers, cam is a Comp 292H 292 dur and .560 lift with roller rockers and dual billet roller timing chain. Not sure of the max spark advance off the top of my head. I'm running a Edelbrock 750 carb if that matters.
Old Feb 1, 2010 | 11:30 AM
Argess's Avatar
Argess
Ah hah!....your dist has been re-worked and you no longer use vacuum advance. We didn't know that before..............
You know I am laughing "with you", not "at you"......it's just funny all the new info you just "let slip".....
Anyway, as a starting place, I'd try an initial advance of 18deg BTDC. With your dist, that should give about 36 deg max at higher rpms.
Try that first and see what happens.
After that, I'd try to get the vacuum advance hooked up again. Leave it off for now until you get things sorted out.
At any rate, I'd be suspicious of the igntion timing and work with it a lot before tearing down the engine due to possible CR problems. Many machine shops don't even mill heads any more....they use a machine with a large sanding belt on it...typically taking off well under 10 thou.
Old Feb 1, 2010 | 11:37 AM
pbear6969's Avatar
pbear6969
I need to get another timing light and try that. We tried that with the timing light I have and I think it is wrong or something. Cause at 18 BTDC it won't start or it kicks back on the starter. Might have to borrow my buddy's digital MATCO timing light and try it. Something a little better then my adjustable Craftsman. I know this thing has been driving me crazy. You think a stock or different dizzy would be worth a try? My dad has a Mallory dizzy on the shelf that is suppose to be like a stock one only without points.
Old Feb 1, 2010 | 11:45 AM
Argess's Avatar
Argess
er....confusion....you stated earlier it runs about 32 deg at idle, but now you say at 18 it kicks back when you try to start it? Somthing ain't right here.
I was gogin to explain how to set it up without a light, but that's old school and may not work as you have an igntion box.
I think an MSD expert is needed here. If the igntion box is adding advance, and the dist is adding advance, how can anyone predict what will happen and if it will happen correctly without using a timing light throughout the rpm range?
Old Feb 1, 2010 | 11:56 AM
pbear6969's Avatar
pbear6969
Yeah I kind of wondered if something else wasn't messing with the timing or my light is totally screwed up. One thing I thought was the Petronix unit is the one that adjust the dwell for the best performance. I thought that might be causing it but not sure.
Old Feb 1, 2010 | 04:59 PM
Moto Mel's Avatar
Moto Mel
You neeed to start over.
1. First bypass the MSD system you can re-use it after the truck is running.
2. Turn the engine over by hand to 12* btdc.
3. Make sure all power wires are correct and the plug wires are in the correct firing order.
4. Using a lighted probe on the wire to the distributor rotate the dist. until you get light when the rotor is pointing at the location of the #1 plug wire in the cap. The cap will be off the dist. for this.
5. Tighten the dist. clamp just enough to hold it but still be able to rotate it for adjusting the timing, reinstall the cap.
6. Start the engine.
Good luck with it and let us know how it works out.
Old Feb 2, 2010 | 11:24 PM
Moto Mel's Avatar
Moto Mel
Copper Head Gaskets
mailto:copper@headgasket.com
Not in the Chicago area but they have the right products, head gaskets up to .125" thick. These guys should be able to cure your problem.
Let us know what the fix is..
amd_038
Aug 5, 2012 09:42 AM
JimNolan
Jan 26, 2010 05:47 PM
BlueOvalBud
21
Jan 10, 2010 05:50 PM
pbear6969
Mar 23, 2007 02:39 PM
nminer1
Apr 19, 2005 10:28 AM
