Larger intercooler question
Old Jan 26, 2010 | 07:06 AM
rat49f6's Avatar
rat49f6
i found mine on cl for $150 lots of 6.0 guys do the banks kit
Old Jan 26, 2010 | 07:21 AM
Izzy351's Avatar
Izzy351
Here is a pic of both:
Old Jan 26, 2010 | 07:23 AM
Ponyboychris's Avatar
Ponyboychris
Do you need different boots when swapping to a 6.0 IC?
Old Jan 26, 2010 | 07:32 AM
Izzy351's Avatar
Izzy351
Yes. One 3" to 3". My 7.3 cooler had 3.25" inlet/outlet, the 6.0L cooler had a 3" inlet.
Old Jan 26, 2010 | 08:29 AM
RV_Tech's Avatar
RV_Tech
Other than the boots, it this pretty much a drop in?
Steve
Old Jan 26, 2010 | 08:49 AM
Izzy351's Avatar
Izzy351
Steve
Yes. You'll have to move the AC condenser a little to get the outlet around the lines, but it'll go. Check with Clay for the boot you need.
EDIT: If you have an Auto Trans, you'll need a different cooler though. The lines off the stocker go right where the extra length of the IC stick down.
Old Jan 26, 2010 | 08:54 AM
RV_Tech's Avatar
RV_Tech
Thanks, I have a auto trans cooler off a 6.0 liter to install, so I'll have to look things over.
Steve
Old Jan 26, 2010 | 09:02 AM
Izzy351's Avatar
Izzy351
You're good to go then. The 6.0L cooler lines exit the bottom of the cooler, stocker exit the top. If you click the pic I posted, it'll take you to a bunch of pics I took of my install.
Old Jan 26, 2010 | 09:39 AM
Ponyboychris
Thanks, Joe. I'm starting to see a couple of 6.0 IC's pop up on CL around here and was wondering if this will be a good fit for my rig. I do tow a moderate sized 5'ver and at the altitudes that I tow in, I want every advantage I can get.
Old Jan 26, 2010 | 10:20 AM
CSIPSD's Avatar
CSIPSD
Originally Posted by jkidd_39
I got mine for $150 and I think it's a great upgrade!! My truck is a work truck tho.. If you use your truck to make $$$ then it is very cost effective.
If you are dropping big $$$ on hybrids, H2E or T4 turbo set up and big oil then you prob got the $$$ to drop on a $1200 IC..
Water Injection is another good addition.
What part of I am running one did you miss?
When I installed mine I was running stage 2 injectors and a Van turbo... Saw less then a 50* drop when pulling and nothing empty.
Both, It's like 30% larger. And it flows better. If you get one and compare them it's obvious.
I didn't take a pic of a 7.3 and 6.0 compared.. darn.. I just got the 6.0 transmission cooler vs. 7.3 transmission cooler..
There are some pic's for you, the 7.3 is wider for the core, but the 6.0 is taller and thicker. It flows about 20% more at best.
There are very nice all metal IC's out there for less then $700 that give you a real loss in EGT's.
And BTW...Mine is a work truck, pulls more weight then most every day, day in and day out.
Old Jan 26, 2010 | 10:24 AM
RV_Tech's Avatar
RV_Tech
I am still researching this topic and have found prices on the aftermarket coolers vary widely. Are they comparable or does price make a difference? I have a hard time separating advertisers hype from reality.
Any thoughts?
Thanks,
Steve
Old Jan 26, 2010 | 10:28 AM
MobeyDick's Avatar
MobeyDick
Originally Posted by Two by Ford
What's a good deal? and is E-Bay and CL the places to lurk?
Free a buddy put a banks kit on his 6.0, he gave me the 6.0 IC. All I had to do was buy the boots.
Old Jan 26, 2010 | 10:39 AM
  #28
Izzy351's Avatar
Izzy351
If you need a big drop, then spend the $$$, like Joe said. If not, a good deal on the 6.0L is okay. My van turbo made the biggest difference in my EGTs. I was able to get over 1500 with stock sticks. After the turbo & IC, I could barely get to 1300. Now I can really spike them again with the hybrids.
Old Jan 26, 2010 | 10:45 AM
  #29
CSIPSD's Avatar
CSIPSD
Any thoughts?
Thanks,
Steve
PM DeputyDog on here... He has a diesel site and sells a all metal IC for, IIRC, 600-800...
nossliw
66
Sep 2, 2016 10:48 AM
Mishimoto
6.4L Power Stroke Diesel
Dec 9, 2013 03:11 PM
Ford F834
Apr 7, 2012 06:32 AM
Acewelder99
30
Jun 1, 2008 06:39 PM
