fuel pressure problem
Old Jan 25, 2010 | 04:41 AM
Home made SVT's Avatar
Home made SVT
I have a 460 with a nice cam and intake and a little head work a fairly mild build but i'm haveing fuel pressure problems because it only has a stock pump on it. I know i need a bigger pump but i was wondering what fuel pressure i should be looking for and if i should stick with a mechanical one or go with an electric one?
Old Jan 25, 2010 | 08:39 AM
mark a.'s Avatar
mark a.
I use a stock pump on mine with a Holley 750 dual feed with no problems. If you are having problems and the pump checks out ok there could be a small hole or leak in your line somewhere. There is no reason why a stock pump shouldn't work for your engine.
Old Jan 25, 2010 | 03:25 PM
Home made SVT
the pump i have on it is brand new and runs 6#s at idle but it drops as i rev it up especially around 3 grand. the truck that i have it in used to be fuel injected and I'm still using the stock style fuel filter, could that be causing my problems since that filter is intended for a high pressure system?
pickenspolitics
Jan 23, 2014 06:49 PM
BearFootCustom
Apr 29, 2013 03:58 PM
fixxxer-upper
Dec 14, 2011 11:30 AM
bronco cam
1978 - 1996 Big Bronco
29
Jun 13, 2011 02:59 AM
fireplow970
Nov 11, 2006 06:18 PM
