EFI fuel pressure question
Old Nov 10, 2006 | 04:34 PM
fireplow970's Avatar
fireplow970
I have a 1988 F150 with a 300 six with EFI. I think I am having fuel pump problems and plan to check my fuel pressure with a gauge I recently bought. Can any one tell me what the pressure range should be with key on - engine not running and engine running? Thanks alot.
Old Nov 10, 2006 | 05:17 PM
Ranger GT2's Avatar
Ranger GT2
Attach the gauge to the fuel rail and without starting the engine just turn the key to the on position (the pump should run for a few seconds) and see what the pressure is. Start the engine and check the pressure. I don't have a manual for that year but it should be around 30 to 35 psi I would imagine. If you unplug the vacuum line to the fuel pressure regulator your reading on the gauge should go up about 10 psi. Thats with the engine running.
Old Nov 10, 2006 | 10:39 PM
optikal illushun's Avatar
optikal illushun
45-60 psi...
Old Nov 11, 2006 | 06:18 PM
stractor's Avatar
stractor
Just did the same thing--45psi with regulator connected----55 with regulator vacuum disconnected.
stractor
gt5-33
Large Truck
Apr 17, 2018 06:10 AM
rhoward
Jun 22, 2013 08:22 PM
isuis1
May 8, 2008 10:13 PM
monarokid
Aug 29, 2007 04:41 PM
spiritradio
1978 - 1996 Big Bronco
Nov 22, 2006 05:29 PM
