Part number help....numberdummy...anyone????
Ok, I need a coupla parts...I have a 1979 F150 Ranger XLT 4x4. I need a headlight switch, drivers side window winder motor and, finally a fuel filler spout, the metal part the cap attaches too, oh, and a cap!!
I am happy to buy 2nd hand if they are in good condition. Also I am looking for door control rods, the ones that operate the lock mechanism.
Thanks,
Shane
Thanks,
Shane
Sure am....
You betcha I am!! Do you accept PayPal? I am in New Zealand, but I have a buddy in Tennessee, if you would rather send it to him? I will pay freight etc up front of course.
My headlights flicker on and off.....and from what I have read, the switch is on the way out!!
Cheers,
Shane
Cheers,
Shane
is your dimmer switch on the floor?
check to see if it is corroded, mine had the headlight flicker problem, the bottom of the dimmer switch was corroded/mostly gone and full of crap
seems as though a windshield leak allowed moisture to get under it and it stayed wet.....die cast case against steel floorpan= galvanic corrosion
wires/connector was not damaged, just replaced the $4.00 dimmer switch
worth a check............
grounds to the headlights can cause similar issues also
check the site about re-doing the lighting circuit to the headlights using relays, did it and converted to halogen sealed-beams.............unbelievable brightness, I don't have to strike a match to see if te headlights are working anymore
Thanks,
Shane
Thanks,
Shane
Fits: 1978/79 F100/350 & Bronco // 1973/76 Torino/Montego / 1973/78 LTD w/o Hidden Headlamps / 1974/80 Pinto/Bobcat / 1974/78 Mustang II / 1973/77 Maverick/Comet / 1975/80 Granada/Monarch.
MSRP: $52.89 // FTE sponsor PARTSGUYED.COM price: $28.56.
Window winder motor? Do you want the window regulator, or something else?
Power windows were not available until 1981.
D8TZ1023201A replaced D3TZ1023201A .. Left Window Regulator / Obsolete
Fits: 1973/79 F100/350 & 1978/79 Bronco.
BISON MOTOR CO. in Great Falls MT has ONE = 406-727-2552.
DUVALL MOTOR CO. in Clayton GA has ONE = 706-782-4231.
GRIESEL MOTOR CO. in Okarche OK has ONE =7242. 405-263-
GREEN SALES CO. in Cincinnati OH has TWO = 800-543-4959.
MILLER OBSOLETE PARTS in Binghamton NY has TWO = 800-546-7278.
Fuel filler spout? Are you asking for the fuel filler neck? There is more than one type of filler neck, more than one type of fuel cap.
Styleside or Flareside? / Mid-Ship or Aft Axle Fuel Tank? / With or without Evaporative Emission?
D9TZ1022134A .. Rod-Right Door Lock Cylinder to Door Latch / Obsolete
KINSEL L/M in Beaumont TX has FIVE - 800-816-2894.
DON SANDERSON FORD in Glendale AZ has 37 = 623-842-8762.
D9TZ1022135A .. Rod-Left Door Lock Cylinder to Door Latch / Obsolete
KINSEL L/M has FOUR.
DON SANDERSON FORD has 29.
Fits: 1979 F100/350 & Bronco / 1973/78 is not the same.
2) D9TZ1021852A replaced D3TZ1021852A .. Rod-Right/Left Door Lock **** to Door Latch / Obsolete
DON SANDERSON FORD has 90.
D5TZ1021940A replaced D3TZ1021940A .. Rod-Right Inside Door Handle Remote Control to Door Latch / Obsolete
DON SANDERSON FORD has 60.
D5TZ1021941A replaced D3TZ1021941A .. Rod-Left Inside Door Handle Remote Control to Door Latch / Obsolete
KINSEL L/M has EIGHT.
DON SANDERSON FORD has 25.
2) D5TZ1022152A .. Rod-Right/Left Actuating Outside Door Handle to Door Latch / Obsolete
KINSEL L/M has SIX.
DON SANDERSON FORD has 57.
Whoa....thanks a heap guy's....
I am overwhelmed with the responses from you guys!! Really, you blow me away.
Bill, if you don't mind me useing your name, someone must have grafted power window into it, so I do need a motor, the regulator is missing too, but the previous owner still has it, and say's he will send it to me. It is the fuel filler neck and cap I require, for a styleside. As for evaporative side, I don't know, but I am sure I can make either of them work.....I will take what ever I can get.
Whiskeyrider, Starmilt, let me know your PayPal account, and I will send you the money for the parts....and an address in the 'states, my buddy will ship from there.
Cheers guy's, once again, I thank you!!
Shane
P.S, I am really lovin' the truck....not the gas consumption....but I love it....fuel is NZD $16.00 a gallon down here.....
Shane
Texas Outlaw
01-14-2007 10:19 AM
pilot4x4
09-01-2004 09:21 PM
GregCS
07-05-2000 09:52 PM
