Looking for Parts
Old Jun 28, 2014 | 11:41 AM
mosigndude's Avatar
mosigndude
Looking for Parts
1966 Ford F100 4WD, SWB, NP-435 4 Speed, Styleside, 352
ND or others, as usual I am in need of another part number and nos if it can be found. I am dressing out the transmission stick shift and noticed the retaining cap for the stick shift is in need of repair or hopefully nos replacement.
Essentially, this retaining cap pushes in and twist locks onto two pins to retain the domed grease cap (with spring underneath) and the stick shift itself. Any help would be greatly appreciated.
Old Jun 29, 2014 | 12:20 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by mosigndude
1966 Ford F100 4WD, SWB, NP-435 4Speed, Styleside, 352
B8T-7220-D .. NP435 Shift Lever Retainer Cap / Obsolete
This spring loaded cap has two notches, is retained to the shift tower with two pins. To remove it, it must be pressed down and held down while turning it to remove it.
People unaware use pliers or channel locks in an attempt to remove it, which tears out one/both of the notches. Not Pleasant!
SEVEN Ford dealers in MO have 1 each, if you list the city you live in, I'll give you the closest sources.
GREEN SALES CO. in Cincinnati OH has 2 = 800-543-4959.
TISON MOTOR CO. in Estill SC has 3 = 803=625-2551.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 43 = 800-476-9653.
Old Jun 29, 2014 | 10:34 PM
mosigndude's Avatar
mosigndude
Thanks ND! It definitely looks like some one tried to rip it out and then hammered it back the best they could.........I live in Fordland, MO.....m
Old Jun 30, 2014 | 11:41 AM
NumberDummy
WEHR FORD in Mountain Grove MO has ONE = 800-228-6827.
SAKELARIS FORD-LINCOLN in Camdenton MO has ONE = 800-367-3311.
NEVADA FORD-LINCOLN in Nevada MO has ONE = 417-667-3385.
Old Aug 14, 2014 | 03:28 PM
militos's Avatar
militos
Thanks for the pressdown stick cap information, Yesterday I tock my truck to have the clutch replaced,,and the mechanic unfamiliar with this old trucks broked one of the ears in the pressing cup at the moment of removing the stick from the trans.
I'll try to order one from Carpenter, do any one knows the exact CARPENTER part number?? I visited the site but there is no such thing.
Thanks very much.
I'm Having fun with my 66 F100 Beast since it's my primary commuter..
militos.
Old Aug 14, 2014 | 03:29 PM
militos's Avatar
militos
by the way I/m in the San Francisco/ San JOse California Area.
Thanks.
militos
Old Aug 14, 2014 | 04:23 PM
gangstakr's Avatar
gangstakr
Thanks very much.
militos.
Whe I first read this post I had access to a shifter as described. I pulled it just in case the OP needed one. After contacting the OP it seems as he has his problem under control.
I still have the shifter I'll post pictures in a little bit.
Old Aug 14, 2014 | 05:38 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Thanks very much.
militos.
That's not the normal Carpenter phone number but is for their NOS parts group. You can't really get much info through that line as they want people to submit a price request through one of the online parts search engines and they will e-mail you back with a price quote and then you can call the normal 800 number (not the toll number listed above) and order the parts. Use the part number that ND listed above.
You have to play by their NOS rules or they won't help a person. Been there, done that.
Old Aug 14, 2014 | 08:14 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Two of my trucks have NP435 so after looking at the service manual I made my own NP435 Shift Lever Retainer Cap removal tool from a piece of 1.5" diameter pipe cut to about 2" in length. Then I just open up a pair of vice grips large enough to hold the pipe, remove the shift **** and boot and slide this down over the lever and use the vice grips as a handle to help press down on the cap. The pipe distributes the downward pressure evenly and grips the cap enough to turn it.
Old Aug 18, 2014 | 11:14 PM
militos's Avatar
militos
Thanks very much every one.
militos.
Old Aug 19, 2014 | 06:54 AM
crazed87bronco's Avatar
crazed87bronco
TA455HO i like the tip you gave on removing the cap. It took awhile for me to get mine out the first time I did it. I'll try it your way next time.
tashbyl
Feb 5, 2022 02:39 PM
kenny nunez
May 27, 2019 01:46 PM
Queueball
Feb 1, 2013 02:01 PM
qman
Nov 1, 2008 10:58 AM
rb7604
22
Oct 27, 2008 03:53 PM
