HELP
Yes, gasket kits for FE engines should work for any size or year of FE; however, you may get a few extra gaskets that you will not use. The kit will probably have carburetor gaskets for both 2BBL and 4BBL carbs as well as exhaust gaskets for both GT heads and regular (truck) heads. You might be paying for these extra gaskets you won't use, but it does cut down on confusion for those behind the parts counter as well as their inventory.
BTW show the person your known 360 in your other truck and see what he calls that engine. If he says it is a 351M or 400, tell him to go back to automotive school; or better yet, tell him the address of this web page!
Is there anything that you recommend that we check before we drop it in?
352,360,390 there are more FE's but these were the stock truck ones)and Big Block
351M,400,460) The mounts can differ. I got a smallblock C6 to go behind my 302 in my 76 F100(not a stock setup, a 302 would have had a C4) and I had to drill new holes in the frame about 3" back of where it had been for my original 3sp. I believe that the tranny had originally come in a car such as a cougar or Lincoln Versaille. I had to find a proper dipstick tube for my application and have my driveline shortened. Other FE motors that weren't used in pickup trucks but were used in Ford,Edsel, and Merc cars of the 50's & 60's include: 332,361,406,410,427,428 (429 is not an FE it's related to the 460) Tranny sources might be transferable with some minor modification from such things as T-Birds,Galaxies,Failanes (w 390), Mustangs, Cougars,(390,428) I'm assuming, that all FE bellhousings are the same, this might not be the case, you'd best get a confirmation on that, Ford isn't always uniform about these things. For instance, early 289's in 64,and into 65 had a 5 bolt bellhousing that is different from the 6 bolt pattern that has been used since on later 289's,302,351W,351C. For a very short time the first 351M shared the smallblock pattern but then changed to the big block pattern. As far as I know FE engines all have the same bellhousing pattern. If this is true then the car sources I mentioned may be an option. TIMING COVER CSAE-6059-B 6. ALSO ON THE TIMING COVER IS A CIRCLE WITH 68 AND5 DOTS INSIDE. sPARKPLUGS, (4)W, 89, (5)48EL,(6)C8AE-H. THE ONLY OTHER THINGS ON THIS MOTOR ARE FIRING ORDER AND ON THE BLOCKE IS ALSO A CIRCLE WITH AN ARROW AND 10 DOTS ALMOST LIKE A CLOCK. mAYBE SOME OF THESE ARE WHAT YOU NEED.
The exhaust manifold number indicates a car part but not a biggy since they do fit. The head number is a standard 360/390 head not necessarily unique to either a car or truck. Based upon everything you stated so far though, I feel comfortable that you have an FE block in either 360 or 390 cid. I may be able to narrow this down further by telling you what this displacement block started out as. However, due to the magic of machining, that block could have been transformed. Therefore, the only true method of identification is a total disassembly and an accurate measurement of all components. Please repost just the number you found on the block on the lower passenger side rear near where the starter bolts on to the bell housing. Did you try the wooden dowel trick for measuring the storke which is described on my website? Most everything else I can tell you about your motor will only serve to feed your curiousity not necessarily give you any useful information.
Stock Man
1967 Galaxie 500 Convertible (HELP!---I need 15 x5 factory rims)
1967 F-250 FE 390 4wd
1966 F-250 I6 240 2wd LWB Flare Side
<a href="http://www.hometown.aol.com/tbeeee">http://www.hometown.aol.com/tbeeee</a>
