PATS Key programming problem...
Old Jan 23, 2010 | 09:33 PM
CMOS's Avatar
CMOS
Hey All,
I've programmed several PATS keys over the last 10 years but am having trouble with the latest one.
2001 ST, followed the usual procedure but the new key will not start the vehicle.
Any suggestions?
CMOS
Old Jan 23, 2010 | 10:28 PM
shorod's Avatar
shorod
It sounds like you've programmed more of these than I have so I have to start with the basic questions. Did you perform the steps outlined in the owner's manual or go off of memory from a different model and year? Second, what indications do you get when trying to start the Sport Trac using the new key? Does the engine crank? Do you get a flashing or solid "Security" or "Theft" indicator in the instrument cluster?
-Rod
Old Jan 24, 2010 | 08:32 AM
CMOS's Avatar
CMOS
After attempting to program the "new" key, when inserted in the ignition I do get the blinking "Theft" indicator light (which I do not see with the original 2 "good" keys.)
I was going off memory as far as procedure, but I did check the procedure in the manual and I was indeed doing it correctly.
Thoughts?
CMOS
Old Jan 24, 2010 | 10:06 AM
shorod's Avatar
shorod
Based on the 2004 Transponder Guide, 7th edition from Ilco, it appears there was a transition in mid-01 for the model of transponder key with the Explorer and Sport Trac. Is the key you're trying to program an OEM key for the build date of the vehicle or a generic aftermarket key?
-Rod
Old Jan 24, 2010 | 10:22 AM
CMOS's Avatar
CMOS
-Rod
OEM. Bought it from a local Ford dealership.
CMOS
Old Jan 24, 2010 | 11:41 PM
Moto Mel's Avatar
Moto Mel
Be careful trying the new key that will not work. I found out the hard way that trying the non programmed key too many times in a row causes the PATs to totally disable the vehicle. Requiring a trip to the dealer or having a smith do a reprogram on the vehicle.
Old Jan 25, 2010 | 06:50 AM
shorod's Avatar
shorod
I thought that only caused a 15 minute or so disable....
-Rod
Old Jan 25, 2010 | 07:02 AM
Moto Mel's Avatar
Moto Mel
-Rod
I was not that fortunate, it cost me $120 to learn.
Old Jan 25, 2010 | 02:16 PM
shorod's Avatar
shorod
I was looking at the owner's manual steps from Fleet Ford and noticed a timing requirement in steps 1 and 3 which could be pretty easy to overlook. Were you making sure you kept the ignition in the On position for at least 1 second?
"1. Insert the first previously programmed coded key into the ignition and turn the ignition from 3 (OFF) to 4 (ON) (maintain ignition in 4 (ON) for at least one second)."
and
"3. Within ten seconds of removing the first coded key, insert the second previously programmed coded key into the ignition and turn the ignition from 3 (OFF) to 4 (ON) (maintain ignition in 4 (ON) for at least one second but no more than ten seconds)."
I was actually searching the owner's manual for information related to the number of attempts before it locks out the ignition and to see if there was a time associated with that. I found nothing. It does seem like that could be important information for the vehicle owner to be aware of.
-Rod
snakedoc
13
Jan 17, 2014 08:16 PM
white Buffalo
40
Oct 18, 2011 11:38 AM
cobrarep
Aug 3, 2008 01:13 PM
Nick37
1983 - 2012 Ranger & B-Series
24
Jan 12, 2007 01:08 PM
br6ad
Apr 23, 2004 07:24 AM
