Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Fuel filter question?
Old Jan 23, 2010 | 03:33 PM
klexow150's Avatar
klexow150
Are there any special tools or tips needed to change out the fuel filter on a 04 escape? Wondering if the system needs to be depressurized before removing old filter and if you need that special fuel filter wrench to remove it?
Old Jan 23, 2010 | 05:18 PM
bmuhlbach's Avatar
bmuhlbach
nothing fancy needed two clips to pull out and a hose clamp that holds it in the bracket so a flat blade screw driver or a 5/16 nut driver.As for preasure I do mine after they set for an hour or so or longer then there is no preasure in the lines.
Old Jan 24, 2010 | 06:35 AM
Dan Robertson's Avatar
Dan Robertson
I have a shop towel handy and cover the filter with it when I release the pressure. I also move my drop light to a safe location.
Albert Sanchez
Oct 5, 2013 07:05 AM
wraysp
Jun 12, 2010 05:30 PM
fowler250
Jan 8, 2007 06:20 PM
slangvel
May 7, 2005 09:13 AM
czabala
Oct 11, 2004 11:34 AM
