Replacing ECT Sensor
Old Jan 23, 2010 | 08:14 AM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Should I change the ECT sensor when replacing the water pump? NAPA has them for $15 with the part number MPE-T540475B. I have an 2002 F-350 automatic.
Thanks...
Old Jan 23, 2010 | 10:04 AM
mueckster's Avatar
mueckster
I wouldn't change it unless you are experiencing a problem. If I have to change mine it will be a Ford/Motorcraft item. I've changed 2 waterpumps on my truck and have over 160k miles on the OEM sensor.
Old Jan 23, 2010 | 10:05 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
No. Don't waste your money. If the gauge in the instrument cluster is working, then the sending unit is fine. The coolant temperature sensor serves no function at all for engine control in a truck like yours.
Old Jan 23, 2010 | 11:09 AM
Whitey Ford
Thanks. I can't believe I got 166k miles out of the stock water pump, belt, hoses and ECT sensor.
So I just pull the sensor and clean the treads and re-apply a clean coat of TFE paste to the ECT before installing on the new pump? The pump bolt threads don't need it right?
Do I put the NAPA Sil Glyde on the whole WP oring gasket, or just in parts to hold it?
Thanks...
Old Jan 23, 2010 | 11:18 AM
mueckster's Avatar
mueckster
Paste type sealant is good on the sensor, since the threads need a good ground. I use a little ani-seize, or the thread selant,on the bolt threads also. It makes them easier to remove the next time they need to be removed. I put a thin coat of Sil-Glyde on the entire gasket and a few larger dabs to hold it in place. I may not be necessary, but the last gasket got pretty stiff and leaked after 50k miles. I put the S-G on the gasket for good measure.
Old Jan 23, 2010 | 11:19 AM
Izzy351's Avatar
Izzy351
The dealer replaced mine along with the 'stat when I bought my truck from them (it had 60k on it). I still don't know why they did both -- shotgunned parts?? The temp sensor barely moved and it took FOREVER to the heat to start working. Maybe both were bad??
Old Jan 23, 2010 | 02:02 PM
Whitey Ford
Thank you...
DesertZuki
Dec 14, 2015 11:35 AM
phishfood4311
Modular V8 (4.6L, 5.4L)
Sep 9, 2015 06:01 AM
socal00
Feb 10, 2012 11:02 PM
acetrebo
Jun 29, 2008 10:28 AM
pomial
Jan 18, 2007 07:56 PM
