ECT; Engine Coolant Temperature Sensor
Old Dec 13, 2015 | 02:15 PM
DesertZuki's Avatar
DesertZuki
Trouble Code 18 continued.
Symptoms:
Surging idle, i.e. 400 RPM to 1100 RPM
Starts good cold; almost impossible to start warm
Temps checked with an IR gun pointed at the thermostat housing; resistance across the terminals of the ECT
at 62 degrees, 43.7 2k ohms
at 143 degrees, 6.1 2k ohms (edit: 2k is a typo -- 200k is correct)
When I unplug the ECT, the surging idle is gone but it is still very hard to start warm.
Replace it? Circle Yes or No.
Old Dec 13, 2015 | 04:52 PM
DesertZuki's Avatar
DesertZuki
I should add I just found out it has a fuel pressure leak down problem, from the injector according to my test. Still, the ECT question stands.
Old Dec 13, 2015 | 09:40 PM
Gary Lewis's Avatar
Gary Lewis
Here's where the 1986 EVTM would nail it. (Bill?) That's 'cause my '81 EVTM includes an ECT for the EEC system, but the EFI system wasn't out yet. In '81 the ECT for the EEC was the same as for the gauges, meaning it has a range of 10 ohms at the top temp, to 73 ohms when cold. However, I don't know what ECT was used for the EFI system.
Assuming your "2k ohms" is the scale you were on, then it is quite possible that the 6.1 ohms would be more like 15 ohms if you'd used the 200 ohm scale. And, that would mean your ECT is probably working. However, they are cheap so you might want to change it if fixing the fuel leakdown doesn't fix the problem.
Old Dec 14, 2015 | 12:24 AM
DesertZuki's Avatar
DesertZuki
Gary, could leaky injectors cause idle surge?
Yeah, I just spent $120 on three 1986 manuals, but missed the emissions manual, darn it.
For the ECT resistance check, I was using the below chart. It makes me think the ECT is working, but I wonder about the motor not surging at idle when it's unplugged. I used the 200k (not 2k -- typo) scale as per these instructions: "Connect an ohmmeter between the ECT sensor terminals, and set the ohmmeter scale on 200,000 ohms." from: ECT - Engine Coolant Sensor - FreeAutoMechanic It appears they assume the resistance is universal.
Old Dec 14, 2015 | 06:38 AM
Gary Lewis's Avatar
Gary Lewis
I'm not au fait with EFI, being an old-school carb kinda guy, but I would expect that injectors that dribbled fuel would cause problems with the idle. A drip would cause an imbalance in the air/fuel ratio and probably cause the RPM to drop.
And, the computer knows when you unplug the ECT so goes into a fail-safe mode, and that will change the RPM.
Old Dec 14, 2015 | 11:35 AM
DesertZuki's Avatar
DesertZuki
Thanks, Gary. I appreciate it.
I'll assume (for now) that it is working and I'll replace the injectors and try it again.
I have to admit to being mystified as how this pickup seemed to run so well when I test drove it, and since then, it's been identify one problem and three more present. Pickup lust maybe...
Edit: I just noticed that in my third post, I posted up the chart for the IAC (Intake Air Charge Sensor). Easy enough mistake, I guess. The values are the same.
weswes01
Nov 12, 2007 09:08 PM
michigan66
1983 - 2012 Ranger & B-Series
Dec 10, 2005 07:45 PM
jmca
Jan 18, 2005 04:47 PM
rick_mack
Nov 26, 2002 07:02 PM
tomucen
Aerostar
Jan 8, 2002 10:11 AM
