Sponsored by: Real Truck
superduty front axle
Old Jan 21, 2010 | 07:25 PM
mrwrench's Avatar
mrwrench
hi , i want to know what is the difference between 05/07 and 08/09 front axle for a superduty.
thanks all
Old Jan 22, 2010 | 12:59 AM
FI460's Avatar
FI460
I believe they're both dana 60's.
Old Jan 22, 2010 | 01:02 PM
Furian's Avatar
Furian
You Keep What You Kill
I reviewed Icon's lift kits for the 2005-2007 SD's versus the 2008-2010 SD's and from the pics determined that there is a difference in the sway bar design. In the pics below, you can see the subtle differences...
2005-2007 4.5" Lift Kit:
2008-2010 4.5" Lift Kit:
Old Jan 22, 2010 | 01:43 PM
mrwrench's Avatar
mrwrench
yes the sway bar is diff -what about dimensions -hubs- brakes etc ?
Old Jan 22, 2010 | 01:53 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Are you sure the sway bar is actually different? The top pic looks like longer links, the bottom pic looks like a spacer to bolt onto the upper mount. I've seen both types for the 05-07 years, depending on the maker.
Old Jan 22, 2010 | 02:08 PM
cartmanea's Avatar
cartmanea
'08 and newer have the sway bar in front of the axle and '07 earlier is behind, correct?
Old Jan 22, 2010 | 02:23 PM
mrwrench's Avatar
mrwrench
the rear sway bar is on 99/04 I think
Old Jan 22, 2010 | 02:34 PM
texastech_diesel
Token Redneck
Front side on the coil spring front ends. This is the drivers side link on my 07. Someone have an 08+ to put up so we can see if theres a difference?
Old Jan 22, 2010 | 02:55 PM
Furian's Avatar
Furian
To the OP, why are you asking this question? It would help to know your objective...
49F1BIGBLOCK
Mar 12, 2013 08:13 PM
buckeyemag53
Oct 1, 2012 07:00 PM
tseekins
Sep 18, 2009 07:52 PM
barebackjake
22
Oct 15, 2008 06:12 AM
skiduty
Sep 30, 2008 08:02 AM
