Air bag light question
Old Feb 16, 2009 | 07:31 PM
robs01f250's Avatar
robs01f250
Just recently my air bag light is coming on when i turn the truck on. It will come on the flash for a couple times then it will stay on then flash. I am pretty sure it is because the indicator light is out that lights up when you turn the passenger air bag off. Is there anyway to fix this without taking it to the ford dealer
Old Feb 16, 2009 | 08:59 PM
DieselCamper01's Avatar
DieselCamper01
Hang in there. Someone with knowledge will come along and answer this for you. In the meantime here is a bump.
Old Feb 16, 2009 | 09:14 PM
F350-6's Avatar
F350-6
It's trying to talk to you. Count the number of flashes each time and report back. If it flashes 2 times, then flashes 7 times, that's air bag code 27. Tell us what the code is and we'll go from there.
Old Feb 16, 2009 | 09:52 PM
ernesteugene's Avatar
ernesteugene
Here was my experience and as you can read it eventually fixed itself after the rains stopped and everything got good and dry!
Need Help On Air Bag Warning Light!
https://www.ford-trucks.com/forums/5...ing-light.html
Old Feb 17, 2009 | 07:43 AM
robs01f250's Avatar
robs01f250
I started the truck this morning and I counted the flashes on the light. There was 2 flashes then a pause then 7 more flashes so it is the code 27 what does this mean and is there anyway I can fix it without gong to the dealer
Old Feb 17, 2009 | 07:58 AM
Action4478's Avatar
Action4478
It is definately the Pass side bulb ,,& it is replacable ,,I hear some going to Radio shack for the bulb ...
Old Feb 17, 2009 | 08:44 AM
F350-6's Avatar
F350-6
I'd try this first as well. This is the most common issue we see (which is why I brought up the 27 code in my example).
Old Feb 17, 2009 | 10:15 AM
robs01f250's Avatar
robs01f250
does anyone know how to get the bulb out to replace it?
Icicle
May 19, 2014 12:06 PM
00GT
1983 - 2012 Ranger & B-Series
May 11, 2011 10:46 AM
shark1979
May 30, 2010 08:57 AM
mrcdsmith
May 12, 2004 01:07 PM
