Sponsored by: Real Truck
Day time running lights
Old Mar 16, 2017 | 08:45 AM
speedracer29j's Avatar
speedracer29j
I have a 02 f350 superduty, I recently did the 07 head light conversion. I had a sealed beam style before. I have two questions. How can I make the low beam reach further out, besides shimming up the bottom of the lugh bucket. And is there a way to turn off the daytime running light when the ignition is just on and not the light switch. Or am I beating a dead horse. Thanks.
Old Mar 17, 2017 | 10:39 AM
Mike1's Avatar
Mike1
you should have adjusters on your lights like in this video.
https://owner.ford.com/how-tos/vehic...te-MFPR0815KID
Old Mar 17, 2017 | 11:07 AM
Yama4fitty's Avatar
Yama4fitty
Here is a location description for a resistor you can unplug to drop out your DRL's I found elsewhere:
"On the drivers side, between the battery box, and the back of the headlight is a small metal cage. This cage holds a resistor (large, ceramic type). This cage will be VERY HOT if your lights have been on recently. This cage will be screwed to the metal frame that supports the grille/headlight stuff.
There will be a wire plugged into this cage/resistor combo.
Unplug it and let it hang.
yollup
Jul 2, 2014 07:47 AM
RIKIL
Apr 18, 2014 10:30 AM
mctim64
Nov 6, 2012 05:14 PM
corys46
Electrical Systems/Wiring
May 24, 2008 08:01 PM
rrawlins
Sep 27, 2003 09:14 AM
