C-6 troubles
Old Nov 17, 1999 | 10:19 PM
Bill's Avatar
Bill
C-6 troubles
I recently had my C-6 rebuilt(out of a '70 F250), and it hasn't been right since. Every morning when it's cold, I can hear what sounds like the torque convertor whining. Also, it doesn't want to upshift unless I back off the throttle. When the tranny gets warm, it's all good. Any ideas what could be the problem?
Old Nov 18, 1999 | 05:24 PM
390fe's Avatar
390fe
C-6 troubles
Although I rin a C6 in my F100, about all I know how to fix is the seals, filter and gasket,and band adjustment. I would take it to another tranny shop for trouble shooting. Then, if they find something wrong, go back to where it was rebuilt and ask them if there's something they'll do about it.
Old Nov 19, 1999 | 08:27 PM
Greaseball's Avatar
Greaseball
C-6 troubles
In my expierence when the problem you describe occurs there is something wrong with the lip seals around the pump. Could be that they were damaged during instalation. When you shift in reverse while cold does it take a while before it engages? I have seen this problem a few times and I just do the R&R but when I ask the tranny tech he explains that when the lip seals fail or or get hard, cold fluid passes by reducing the pressure to lock up the clutches but once the fluid warms up the seals soften and the pressure increases.
Old Nov 19, 1999 | 09:32 PM
1BILL's Avatar
1BILL
C-6 troubles
thanks to greaseball for the suggestion. that sounds like that could be the problem. would there be any long term damage caused by this? bill
Old Nov 20, 1999 | 03:53 AM
76highboy's Avatar
76highboy
C-6 troubles
Fordbronco69
13
Jun 18, 2018 12:13 PM
giddyupbronc
1978 - 1996 Big Bronco
Apr 25, 2008 11:08 PM
Tjax
Jun 29, 2005 03:22 AM
makemeknowit
Aug 10, 2003 12:36 PM
mercuryblues
Sep 14, 2002 07:10 AM
