460 Build help
Old Jan 19, 2010 | 11:07 PM
Jdogg44's Avatar
Jdogg44
460 Build help
alright im building a motor for my truck. here are my options, i got a complete 85 460 completely stock, i also have 70's 429. my question is what should i go with? im wanting a high compression motor (11.5:1) with a automatic. im shooting for 500hp. if i go with the 460 should i put the 429 heads on it? has anyone built a high compression motor recently? what pistons are best (and cheap) let me know what i should get.
which heads to use?
Cam?
Intake?
Pistons?
Old Jan 20, 2010 | 07:16 AM
OldRacerGuy's Avatar
OldRacerGuy
You could probably get 500hp with 9.5-10.0/1 compression and run pump gas, why do you want to have more compression? Are you going to run E85 or AvGas?
Old Jan 20, 2010 | 08:27 AM
mwvdub's Avatar
mwvdub
This information is from 429-460.com and gathered by site member DJOHAGIN. This is not my information from a build.
500-525HP 460ci
Intake System:
750cfm Holley DP Carb professionally calibrated for your application
Edelbrock Performer Rpm Intake Manifold
Cylinder Heads:
TFS street heads with mild clean-up (cleaned up good stock heads C9VE, D0VE)
Roller rockers.
Short Block:
Comp Cam XE274H Hydraulic flat tappet cam or equivalent
(Specs:274/286 adv., 230/236@.050, .562/.565, 110 LSA)
Compression around 10.0:1
Stock crank
Eagle I-beam rods
High volume oil pump
Deepened oil pan with windage tray
Exhaust:
1 7/8" headers to dual 3" pipes with H-pipe. Good flowing 3" Magnaflow mufflers or equivalent.
Summary:
91-octane. Keep redline to 6500 rpm.
Old Jan 20, 2010 | 11:50 AM
Jdogg44's Avatar
Jdogg44
i just want that sound that high compression gives. also as im not a big block guy, what if anything needs to be done to oiling system to handle higher compression. and do i need to do anything to the heads if i go with the early 70's 429 head, as far as porting?
Old Jan 20, 2010 | 11:51 AM
Jdogg44's Avatar
Jdogg44
oh about the gas, im gonna run a meth injection system and 93
Old Jan 20, 2010 | 12:03 PM
Jdogg44's Avatar
Jdogg44
oh and another thing has anyone ever used the comp cam "thumpr" series i was thinking of getting the low lvl "big *****"
Old Jan 23, 2010 | 11:37 PM
moose4x4's Avatar
moose4x4
FTE Emeritus
I would go with the 429, in stock form it is about the compression ratio you want. Cam, INtake, Pistons?? What are you using the engine for ? cruising,racing, etc????
Old Jan 31, 2010 | 09:04 PM
quesey's Avatar
quesey
scrap the 429 and build the 460 with the 429 heads.i use trw's 2404 in mine.but the stock heads will need much work to run like you want.i run a comp 294 solid in mine on a 108 cl.really to big but thats what i had laying around and works good with NOS.but with my combo it will put out to the ground 460hp.not at the crank.pm me and i'll send all parts in my motor
Old Feb 10, 2010 | 12:50 AM
65_Ford_F100's Avatar
65_Ford_F100
Sounds like an easy build from DJOHAGIN...
BigBlocker0248
Jan 17, 2016 03:20 PM
rudifisk
Jun 23, 2015 11:37 PM
rudifisk
Jun 23, 2015 11:54 AM
OrFordGuy
25
Jun 14, 2014 05:16 PM
76f1390
21
Feb 11, 2004 12:26 AM
