These were "gross" hp numbers, and you can figure about 80% for net. Some were underrated, and many 429s fall into the underrated catagory.
These also had pretty high compression, 11 or 11.3 for some. This is the "basic" "Thunderjet" engine as found in Tbirds and other pillow barges. CJ and SCJ and Boss engines are rated higher.
I just picked it up from a guy. It runs or ran when it was parked. It is an an original engine i had just planned on rebuilding it and putting a better cam in it and changing the intake and carb. Maybe i'll have to use a slightly thicker head gasket or something
The torque was 480 ft/lbs @ 2800. The 3400 was for the CJ and the Boss but the numbers were lower, 450 ft/lbs for the CJ and and the Boss.
Ford claimed 11.1 to 1 compression ratio for the standard 429, while the CJ was rated 11.3 to 1 with a nominal number of 10.7 to 1, whatever that means. The Boss was rated at 10.5 to 1 compression.
My reference is Ford's Muscle Parts Book, Supplement NO. 1 dated July 1970.
