Question on 460 Head Swap
Old Jun 22, 2015 | 07:41 PM
rudifisk's Avatar
rudifisk
Hi,
I have a 70's era smogger 460 motor that has D2VE-AA heads on it. This is a low compression motor with retarded cam etc. I have a pair of heads from a 429 that are C8VE-E that I would like to use instead. Will the 429 heads be a good replacement? I am concerned about what sort of compression ratio this swap will create. Thanks.
Old Jun 22, 2015 | 08:06 PM
85e150's Avatar
85e150
Lots else to consider, but on heads alone, I think this will give you some numbers to work with to determine your CR.
casting-numbers-descriptions-1-index
Old Jun 23, 2015 | 01:26 AM
rudifisk's Avatar
rudifisk
Yes, that is great info for sure. But what I think I may be asking is what affect on compression does going from a 100cc open chamber (smogger) to a 75-77cc chamber have on compression? I think the smog motor is probably down low, like maybe 8.5/1, just guessing.
Old Jun 23, 2015 | 11:37 PM
85e150's Avatar
85e150
You need all the specs and a compression ratio calculator.
http://www.summitracing.com/expertad...ion-calculator
V10man
Dec 30, 2021 10:48 AM
rudifisk
Jun 23, 2015 11:54 AM
glw165
Dec 30, 2012 05:27 AM
Jokerz Wild
18
Jan 8, 2004 07:16 PM
leadmic
Apr 22, 2003 07:30 PM
