points for 351m
Old Nov 26, 1999 | 08:07 PM
nailbeater's Avatar
nailbeater
points for 351m
I'm getting on with my cab switch. I have a 79 with a 351m and am swaping a cab off of a 74 with a 390. The 79 has electric ignition and the 74 doesn't. I thought if I could find out from you guys if the distributers are interchangable, or if they are not, can I get one with just points for the 351m. This would make the whole wiring alot simpler after swapping cabs. Thanks.
NB
Old Nov 26, 1999 | 09:20 PM
sparky's Avatar
sparky
points for 351m
If you mean are the 390FE and 351M distributors interchangeable, then the answer is no not even close.
If you mean are points 351M and electronic 351M distributors interchangeable the answer is yes.
Why not use the 351M electronic distributor? The wiring isnt that hard to do and you have all the neceesary parts, dizzy,duraspark box and engine wire harness.
Just go to <a href="http://users.erols.com./wrljet/engines/duraspark.html">http://users.erols.com./wrljet/engines/duraspark.html</a>
It shows how to install the Duraspark wiring in the old points type trucks.
Good luck.
Old Nov 27, 1999 | 01:17 AM
Trail Rider
Guest
Posts: n/a
points for 351m
a 460 dist is a direct bolt in swap if you're going after points dist.
Trail Rider
Old Nov 28, 1999 | 11:39 PM
mk's Avatar
mk
points for 351m
The distributor from a 460 is a direct replacement for the 351M/400, so if your heart is set on points, look for an older one of these.
Old Nov 28, 1999 | 11:47 PM
mk's Avatar
mk
points for 351m
Whoops, sorry T/R, didn't mean to parrot your advice. Didn't scroll down far enough to see your message. Guess it's true, that saying-great minds think alike.....
Old Nov 29, 1999 | 06:20 AM
Chuck P.'s Avatar
Chuck P.
points for 351m
restoringmy46
Dec 26, 2010 06:13 PM
74 F100 351m
Jan 20, 2005 04:39 PM
74 Blue Pile
Engine Swaps
Jun 1, 2004 01:28 AM
Crew_Cab+
Electrical Systems/Wiring
May 29, 2004 10:20 PM
