DP Tuner Question???
Old Jan 18, 2010 | 07:52 PM
DieselE's Avatar
DieselE
Gettin ready to order my DP Tuner, what is the difference between the normal tunes(example 60t, 80e, 140e or 140agressive) and the same tunes that say codes.... and what is the difference between 140 extreme and 140 aggressive...
Old Jan 18, 2010 | 08:08 PM
spdmpo's Avatar
spdmpo
The aggressive smokes a lot more than the extreme. Or vice versa, can't remember. The codes tunes help prevent the ICP ? and overboost codes that usually happen when running hot tunes; although you still will probably get an overboost code without an OBA.
Old Jan 18, 2010 | 08:34 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Get the code tunes, and either 140 will yield about the same on a stock HPOP, IMO.
Old Jan 18, 2010 | 09:41 PM
Orezona's Avatar
Orezona
Aren't the Code Tunes just preventing the CEL from illuminating? They are not actually preventing the cause of the CEL light. Correct? Thus, they net the same gains. And if you have a way to pull codes, will you still see them?
Old Jan 18, 2010 | 10:21 PM
Riffraff Diesel
PREMIUM SPONSOR
Originally Posted by Orezona
Aren't the Code Tunes just preventing the CEL from illuminating? They are not actually preventing the cause of the CEL light. Correct? Thus, they net the same gains. And if you have a way to pull codes, you will still see them.
Actually just the opposite, with the overboost code tune will keep you from defueling but will still set the SES so a boost fueler is still recommended.
Old Jan 18, 2010 | 10:27 PM
Orezona's Avatar
Orezona
Why would I need the boost fooler, if the code tune is preventing de-fueling? Sorry Clay, it is a little late here.
Old Jan 18, 2010 | 10:29 PM
Riffraff Diesel
PREMIUM SPONSOR
Nah, no worries man. It wont defuel, but still sets the SES because it senses over ~23psi of boost. The SES goes off after 30 secs, but if you are playing around it gets old.
Old Jan 18, 2010 | 10:38 PM
Orezona's Avatar
Orezona
But if my Overboost Annihilator prevents the MAP sensor from seeing + 24 psi, which prevents de-fueling and the CEL, what is the advantage of the no-code tunes?
Old Jan 18, 2010 | 11:09 PM
Riffraff Diesel
PREMIUM SPONSOR
Good point, I use it because it not only keeps it from defueling it delays it so I can set my fooler a little higher. As well as the ICP and EBP codes as well, as I don't like my SES going off.
Old Jan 19, 2010 | 02:57 AM
CSIPSD's Avatar
CSIPSD
Several other tuners have changed the map to where you dont have to use a map fooler... I have asked before why this cant be done else where but have always been told to run the fooler... Hummmmm
Old Jan 19, 2010 | 07:18 AM
DP-Tuner's Avatar
DP-Tuner
PREMIUM SPONSOR
Well for one if you are running less then 30 psi of boost you won't have to install anything. If you are running an aftermarket turbo that will push your boost higher then 30 psi of boost, Jody recommends that you do install the OBA to help save the diaphram inside the Map sensor. This is why we still sell the ITP OBA kit.
Jody did not want to adjust the voltage code in his tuning so that when you hook up a scan tool you won't be given a lesser reading then what you are actually getting.
Diane
__________________
Jody & Diane Tipton- DP-Tuner®
FTE Legacy Sponsors since 2006
Custom tuning for 7.3l, 6.0l, 6.4l,6.7l, Ecoboost,
Get Tuned! 828-221-0076 ext. 802
Become our Facebook Fan
Old Jan 19, 2010 | 07:33 AM
spdmpo's Avatar
spdmpo
I'm not sure what to say to this Diane, if I were to remove my OBA I'd get an SES light every time. I know I don't need one as it isn't defueling, but still have to run OBA to keep that light off; it gets annoying.
Old Jan 19, 2010 | 07:41 AM
DP-Tuner's Avatar
DP-Tuner
PREMIUM SPONSOR
If you are running the Codes tunes and the OBA and you remove the OBA and you get a code you are most likely getting the Voltage code or you are going over 36 psi of boost.
Bottom line is you need to see which code you are getting.
P0238 Voltage code
P1248 Sensor code.
__________________
Old Jan 19, 2010 | 08:48 AM
spdmpo's Avatar
spdmpo
That is possible, I haven't actually read the codes since I don't have that capability. There's no way I get 36# of boost, so if it's the voltage code what do I do then?
Old Jan 19, 2010 | 09:08 AM
DP-Tuner's Avatar
DP-Tuner
PREMIUM SPONSOR
One is to use Dennis' OBA kit.
The other would be as I described in my previous post. Jody would have to make that adjustment in the tuning, but when you do use a scan tool to get boost readings the scan tool will be not be reading the proper boost. This can also effect the fuel readings as well.
Diane
__________________
