I have a 97 F350 w/460 Last couple weeks it would act up and not bang right off when crankin er over in the morning and a couple times it wouldn't start at all. Left it alone and came back and she would crank right up. Always when cold.
Last Saturday I was delivering a load of wood and about 15 miles into it she would start cutting out then after a few minutes would pick up rpm and go again. Ran fine after about 5 minutes delivered the wood and drove 25 miles back to the yard.
I decided I would shut her off and see if she would start back up, no luck!
I replaced the coil first no luck and ordered an ICM which I'll try and replace tomorrow if it warms up to 15 degrees.
If this doesn't work where do I look next?
