Sponsored by: Real Truck
location of security control module
Old Feb 24, 2010 | 11:32 AM
geraldo14's Avatar
geraldo14
I have a 2002 F-250 Super Duty 4X4 triton V-10. Does anyone happen to know where the security control module is located? my keyless remote system does not work even after programming a new remote. The Ford dealership charged me an hour labor to diagnose the problem and they said it's the security control module which I just ordered. Thanks in advance.
Old Feb 24, 2010 | 12:11 PM
brian42's Avatar
brian42
Veteran: Navy
The dealership installs security systems when the vehicle arrives (at least they used to back in the day when or trucks showed up). I don't know the variances between dealerships, but usually things are installed in the same general location. My security control module is located in the dash. Remove the lower cover on the dash under the steering wheel (four 1/4 turn fasteners that you can undo with your fingernail or a coin). Looking into the opening, look on the right side (opposite side from the fuse box). My unit is a little black box that's zip-tied to the dash bracket on the right side of the opening.
Hope this helps.
Old Feb 24, 2010 | 12:22 PM
geraldo14's Avatar
geraldo14
excellent
Thank you very much for the help, this is great! I'll replace the module in a few minutes.
Old Feb 24, 2010 | 01:01 PM
jdw1's Avatar
jdw1
Just a FYI, I had the dealer replaced mine because they have to suck the info out of it and program the new one with the info they suck out of the bad one.
Hope this makes sence.
Old Feb 24, 2010 | 01:11 PM
geraldo14's Avatar
geraldo14
info
do you mean what programming is input after you program the remotes or is there more to it? thanks for the information.
Old Feb 24, 2010 | 02:45 PM
ColtM4's Avatar
ColtM4
I was told it needed to be programed with all the info specific to your vehicle prior to installation. So for example, 2 door or 4, power door lock or not, power windows, etc. In the end, for me it was a bad instrument cluster that caused my remote door lock/unlock to not work, and kept my dome light on. I have an 02 F250 SD 4x4 PSD. I had an extra security module laying around till I "sold" it to a guy here on the forum. Too bad he didn't pay me
Old Feb 25, 2010 | 09:21 AM
geraldo14's Avatar
geraldo14
module
Wow, the guy didn't pay you? that sucks!! there's some dishonest people out there. Well, the dealership is certain the module is bad so I'll have them install it and program it. Thanks Colt for the post and help.
Old Feb 25, 2010 | 10:04 AM
rotun's Avatar
rotun
Reads ***** rules!
I thought mine went bad too until I realized I had inadvertently put it in Valet mode.
Programming is not that big of a deal though if you can get the install manual.
Old Feb 25, 2010 | 10:11 AM
geraldo14's Avatar
geraldo14
programming
Thanks for the help and post Rotun, nice truck!! I bet that truck can handle anything. I don't have the keyless entry pad on the truck just the key remotes, I wonder if it really needs programming meaning the module or can I do it performing the key remote programming method?
Old Feb 25, 2010 | 10:26 AM
rotun's Avatar
rotun
Reads ***** rules!
Thank you, if replacing the module you will have to program the module as well as the remotes. The module needs to be told what type of electrical system it is hooked up to as many have different types of "grounding" for the door locks, interior light, etc. The install manual will tell you how to figure this out. What is the part # for the module? I might have the programming instructions for it on .pdf.
Old Feb 25, 2010 | 10:47 AM
geraldo14's Avatar
geraldo14
part #
Thanks again for your help, I really appreciate it. The part # is 4C7Z-15604-AC "KIT ALARME/KE
Old Feb 25, 2010 | 12:04 PM
rotun's Avatar
rotun
Reads ***** rules!
Well I couldn't find that part # but these might be the same instructions. Look for the VSS/RKE (Vehicle Security System/Remote Keyless Entry). I think this is for the newer systems but still might work for programming. If not you can try your dealer parts counter and ask real nice for the install/programming for your part #.
File Type: pdf
File Type: pdf
Old Feb 25, 2010 | 12:39 PM
geraldo14's Avatar
geraldo14
thanks
Thank you very much for taking the time to help me and thanks for the PDF files, I'll give it a shot, if it doesn't work I'll stop by the dealership and ask "nicely" for the programming instructions.
Jerry
Old Apr 5, 2017 | 10:01 PM
AntonioCm1983's Avatar
AntonioCm1983
Security module
Seurity module is located to the right of the peddle movement switch in the back behind the panel against the fire wall it will have a grey plug green plug and blue plug attached to in just finished install a new one for my 2005 ford excursion v10 should be same spot for yours
Old Apr 5, 2017 | 11:03 PM
bayou barataria's Avatar
bayou barataria
Just in time, did you see the date on the original post?
