Another EBP sensor question
Old Jan 18, 2010 | 12:59 AM
natew's Avatar
natew
I have lost power and MPG( about 10 all the time).. I have ordered a new EBP sensor and have not installed it yet. WIth the advice from other FTE members, I should use my Edge EVO to check the exhaust back pressure. It read about 13.7 psi at idle and about 16 psi at 1800 rpm in park. I live at almost sea level if that matters on the readings. Does this mean that the EBP sensor is working properly? Is the tube to that sensor the problem? If not, what is my next step?? I have a new 6637 filter and a new fuel filter. Thanks for any help.
Old Jan 18, 2010 | 01:13 AM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
To better check the Exhaust Back Pressure what reading to you get with the key on engine off? What are you getting when you are driving?
Old Jan 20, 2010 | 01:33 AM
natew's Avatar
natew
With the key off I will get 13-14 psi. I just drove it after warming up, and got 40-48 psi with my foot in it. Is this the sensor or something else? If it the tube had holes, the readings would be low? I the tube was plugged, the readings would be high? From what I have read, these readings are normal. I'm still not ready to put in a new sensor because Im not sure this is the problem. Whats my next move???? Thanks again for any help!!!
Old Jan 20, 2010 | 06:08 AM
andrewc53's Avatar
andrewc53
You may want to remove the tube and make sure it's not cloged up. At 103,000 mine was rusted through. A Curtis
Old Jan 22, 2010 | 02:51 AM
natew's Avatar
natew
Just took off the EBP sensor tube. Looks good but there was alot of stuff in the tube. Not sure if it was completely plugged. Put it back together, drove around and the power is back!!! I assume the sensor is good with the reading I got from the programmer. Will a partially plugged EBP sensor tube affect performance and MPG? Thanks for all the help. I love this site!!!!!!!!!!!!!
Old Jan 22, 2010 | 05:28 AM
damicofuel's Avatar
damicofuel
Did you check the fitting in the manifold? Mine was pluged closed.
Cell's
Apr 3, 2022 10:56 PM
SGorman13
13
Feb 14, 2014 03:33 PM
Ford4Life7.3
Nov 1, 2013 11:36 AM
calvinjwilcox
Sep 4, 2010 05:18 PM
natew
Jan 16, 2010 09:47 AM
