6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
did the high idle mod
Old Jan 17, 2010 | 06:19 PM
burrhead's Avatar
burrhead
Yes I finally did the mod thanks to this site,, no upfitters, ran a wire from the lf batt. inside thru the hood latch cable grommet to to a switch connected to the yellow/ grn wire,, put sw. in plastic panel under steering wheel .. works great, will use a lot during summer and any other time during ext. idle situations as trailer hook ups,and when ever..42000 ml,, still love the BEAST
Old Jan 17, 2010 | 06:20 PM
ab257z's Avatar
ab257z
Sounds good - but did you fuse it if you ran it right from the battery?
Old Jan 17, 2010 | 06:23 PM
burrhead's Avatar
burrhead
of course maybe i should have said 15 amp inline to sw.
Old Jan 17, 2010 | 06:28 PM
69cj's Avatar
69cj
3 to 5 would have been plenty and given you a little more protection.
Old Jan 17, 2010 | 08:17 PM
boulderbronco's Avatar
boulderbronco
Excuse my ignorance. If I leave mine idling it automatically kicks the idle up after about 2 minutes. So what is the point of the high idle option? Are the RPM's controlable or is it simply factory set and you either switch it on or off? I know these trucks are not suposed to idle long so the only reason I can see it being nice is in real cold temps when you want to keep it running and not ruing the engine/DPF. But then you have the waste of fuel and emissions arguments. So could someone enlighten me?
Old Jan 18, 2010 | 06:31 AM
ruschejj's Avatar
ruschejj
boulderbronco: The engine idle is elevated when the oil temp is below a certain temp combined with the temp of the ambient air. I don't know the ratio but those two conditions elevate idle automatically and this is what you experience.
When it's warm outside, idle will not elevate automatically. 2 concerns here:
1. High engine load and internal fluid temps, high idle is recommended to keep the fluids hot, keep the oil hot, keep the oil circulating in the turbo housing to cool it effectively, keep the engine block as hot as possible so that fuel economy remains the best it can be, best combustion at highest temps.
2. If you are in a situation where you need to idle for power concerns (electric) or for plain convenience, high idle is recommended to save the EGR system.
It's not a real big deal unless you are one of the unlucky ones that gums up the EGR valve and gets stranded 5 mi. from the nearest road or 500 miles from home at some truck stop. Obviously, it's something that guys make fun of us for too, thinking we are driving "real trucks" where we kick up the idle so we can pretend to be like the Kenworth's and stuff out there. There is a practical reason for it.
Old Jan 18, 2010 | 07:46 AM
ab257z's Avatar
ab257z
High idle is nice for turbo cool down also.
Old Jan 18, 2010 | 05:08 PM
burrhead's Avatar
burrhead
thanks 69cj,,I swapped fuse out with a 5 amp..didnt think about the 15 being to high.. still works fine.
Old Jan 19, 2010 | 09:11 PM
flamebuster's Avatar
flamebuster
Ditto to all the reasons why posted here. In addition at least on my truck the computer kicks to idle up to about 950 rpm. the high idle switch will kick it up to 1,200 rpms. Big difference if you are running a electric winch.
atomicglock
Oct 22, 2013 11:08 AM
mrchip1958
Apr 24, 2010 07:07 AM
joe blow
Jun 18, 2009 09:20 AM
swanee
May 16, 2006 12:34 AM
