High Idle Mod
Old Jun 10, 2009 | 03:13 PM
joe blow's Avatar
joe blow
High Idle Mod
Hello,
I did the high idle mod on my 2004....worked great, thank you guys for the inforamtion.
I have a friend that has a 2007. Does the same hold true for this year of vehicle. Are the wires in the same place and the same color?
Thank you
Old Jun 10, 2009 | 03:18 PM
bpounds's Avatar
bpounds
No. A little different.
This page is for '04 and earlier:
High Idle Mod
and there is a link on that page, to this page, for '05-'06 (and maybe later):
TheDieselStop.Com - www.thedieselstop.com
Old Jun 10, 2009 | 07:51 PM
joe blow's Avatar
joe blow
Thank you bpounds!
Old Jun 14, 2009 | 12:09 PM
MeyerzF350's Avatar
MeyerzF350
Just did this today.....easier than I thought. Thanks guys.
Old Jun 14, 2009 | 12:12 PM
MoyockPowerstroke's Avatar
MoyockPowerstroke
MeyerzF350...was your hot wire the white w/light blue stripe? Do you have upfitter switches, or did you add your own switch?
Old Jun 14, 2009 | 12:13 PM
MoyockPowerstroke
Also, forgot to ask...which setupo did you guys decide on SEIC or BCP...?
Old Jun 14, 2009 | 02:19 PM
MeyerzF350's Avatar
MeyerzF350
I did the BCP to the factory #4 up fitter switch. Works like a charm. I only need this for AC or extended idling in the AZ desert.
Old Jun 14, 2009 | 09:31 PM
MoyockPowerstroke
Since I dont have the upfitter switches...can anyone tell me what the back side (business end) looks like? Does each switch have an illumination light? I want to hook up a Single Pole Single Throw switch with an LED illumination....but it has three blades....hot (dc), ground, and load....does the load and ground get spliced? Without an upfitter switch, I'm not even sure which wire is Hot Key On????Very frustrating.
Old Jun 14, 2009 | 09:59 PM
bpounds's Avatar
bpounds
Here is my info on the switches.
Installing Upfitter Switches - Ford 2005-2007 Superduty
You have an '05, so I would just install the OEM switches.
Old Jun 18, 2009 | 09:20 AM
MoyockPowerstroke
Bill, great write-up and pics on installation of upfitters...I am thinking now, that's the route I'm going to take IOT accomplish the High-Idle mod.
dan.alger
May 24, 2011 11:50 PM
kenlippold
Jan 14, 2011 09:39 AM
2010F350
6.4L Power Stroke Diesel
Sep 6, 2010 10:45 PM
patrickke
Nov 24, 2008 11:25 PM
F450 Aaron
Jul 19, 2007 03:15 PM
