Sponsored by: Real Truck
ignition switch
Old Jan 17, 2010 | 04:10 PM
Diesel_Brad's Avatar
Diesel_Brad
ignition switch
How do you go about removing an ignition switch in an 99 SD.
Old Jan 17, 2010 | 04:25 PM
Tony Gannon's Avatar
Tony Gannon
On my 03 SD you remove the bottom half of the strg. column cowl and you can see on the ign. switch barrel there is a little hole with a round chech ball you push this in as you pull out the ign. switch.
Old Jan 17, 2010 | 04:46 PM
fredsheffield's Avatar
fredsheffield
Do you have a key that works?
Old Jan 17, 2010 | 07:45 PM
bayou barataria's Avatar
bayou barataria
You must have the key in the lock and turned while pushing the pin to remove the switch.
Old Jan 18, 2010 | 04:53 PM
Diesel_Brad
YES. but it get extreamly hard to turn at times. wd-40 helps a lil
Old Jan 18, 2010 | 04:57 PM
bigfordmatt's Avatar
bigfordmatt
this is a little off topic but does anyone have the color codes for the wires off the switch? i am trying to get a remote start on my truck and need the color codes what they goto and what not. thank you
Old Jan 18, 2010 | 05:48 PM
fredsheffield
Dry graphite is best. Sounds like either the key or lock is pretty much done. Better to change it now while you can still turn the key. otherwise you are gonna be hammering and drilling on the pin.
Old Oct 7, 2010 | 11:53 AM
BasicBajaX's Avatar
BasicBajaX
What is that wire that is hooked to the ignition switch as you pull it out? Mine seems to have come apart or broke. It has a peice of metal on the end of the wire that slids in the switch.
Old Feb 7, 2011 | 11:37 AM
ht99vpi's Avatar
ht99vpi
I believe that is the key chime wire, when installing my remote start I happend upon it and when not in no chime, in = chime.
weatherl
2004 - 2008 F150
Feb 2, 2010 10:02 PM
ahurt1973
Oct 25, 2006 02:52 PM
FordDieselPower
Dec 15, 2004 01:46 PM
RGAZ
Sep 30, 2000 08:32 PM
