I am working on a 97 explorer with a 4.0L engine. This thing has been sitting for years and I just started working on it..
I replaced the fuel pump cause it wasn't working and got the truck started and it ran fine for about 2 days. then started running rough so I replaced the plugs wires and coil pack. Now I think that the oil pump is bad cause all of a sudden the valves are tapping. I'm thinking that maybe the oil filer is bad which could be causing the knocking. But I have a new pump and i'm gonna install it.
Is the oil pump directly in the oil pan? Does any one have maybe a manual or proper instructions on how to remove and replace?
I can get the oil pan off no problem but I don't wanna start till someone can tell me 100% that its all in the oil pan.
Thanks for reading this
