Please Help!!!!
Old Jun 3, 2016 | 10:05 PM
klle5's Avatar
klle5
Please Help!!!!
I got a 1993 F250 7.3 idi Turbo 5 spd. I need help with 2 things. 1st When i accelerate hard in 3rd gear i usually get white smoke the more i do it the less smoke.
2nd i have a oil leak. Always leaves a small puddle when i turn the truck off. Starter, Drive shaft, Oil filter, Oil pan is all covered in oil. So was thinking maybe the oil pan bolts were lose but they are tight. (Oil filer is also tight) Seems likes there's a lot of oil and build up in both corners on the oil pan. So is my gasket bad? Also could the oil leak be causing the oil leak? Some how leaking down and getting into the the exhaust? Was reading up online and heard all kinds of reasons on why i could have white smoke. (Smoke doesn't smell sweet smells like a old diesel with maybe a mixture of oil.) Truck has 230,000 miles on it. As far as i believe the injection pump and injectors are all stock. If the oil pan gasket is bad wont i have to pull the tranny off to replace it? Thanks for any help in advanced.
Old Jun 4, 2016 | 12:15 PM
mudmagnet63's Avatar
mudmagnet63
SMOKE COLOR
Basically there are 3 types of smoke emitted from a diesel engine: black, blue and white.
Black smoke:
Black smoke is the most common emitted from diesel engines and indicates incomplete combustion of the fuel. Black smoke causes can vary widely and include ..
· Incorrect fuel injection timing
· Dirty or worn fuel injectors
· Over fuelling
· Faulty turbocharger, or turbo lag
· Faulty or dirty exhaust gas recycling (EGR) system
· Incorrect valve clearance
· Incorrect fuel to air ratio
· Dirty or restricted air cleaner systems
· Over loading the engine
· Poor fuel quality
· Cool operating temperatures
· High altitude operation
· Excessive carbon build-up in combustion and exhaust spaces
Black smoke can occur across the entire operating range, but is usually worst under full power, or during the lag before the turbocharger boosts air supply to match the fuel usage such as in the early stages of acceleration and during gear changes. Moderate turbo lag smoke is acceptable; otherwise black smoke should be hardly visible in a correctly running engine.
Blue smoke:
Blue smoke is caused by engine lubricating oil burning. The oil can enter the combustion chamber from several sources including:
· Worn valve guides, or seals
· Cylinder &/or piston ring wear
· Cylinder glaze
· Piston ring sticking
· Incorrect grade of oil .. too thin and getting past rings, or valves guides
· Fuel dilution of the oil, making it too thin.
Blue smoke is often evident at cold start, which can reflect reduced oil control due to carbon fouling deposits around the piston rings and/or cylinder glaze. Blue smoke should not be evident at any stage.
An engine may burn oil without the evidence of blue smoke, because good compression burns oil quite cleanly, however, it is not acceptable for any new engine, or engine in good internal condition to burn large amounts of lubricating oil.
White smoke:
White smoke is caused by raw, un-burnt fuel passing into the exhaust stream. Common causes include:
· Defective fuel injectors
· Low cylinder compression
Low cylinder compression may be caused by leaking valves, sticking piston rings, ring wear, cylinder wear, or cylinder glaze. When white smoke occurs at cold start and then disappears as the engine warms up, the most common causes are fouling deposits around piston rings and/or cylinder glazing.
Continuous evidence of white smoke indicates a mechanical defect, or incorrect fuel timing.
Look at the valve cover gaskets for oil leaks
BIDIL
Jan 26, 2017 08:42 PM
VT tree grower
Jan 1, 2017 03:32 PM
Nabors
Oct 14, 2015 09:15 AM
77 2wd
Nov 4, 2012 07:03 AM
kystangbanger
Feb 25, 2009 03:45 PM
