strange behavior
Old Jan 18, 2010 | 06:20 AM
RRranch's Avatar
RRranch
So can bad bulbs or connections in teh back of the truck. You don't have LED lights on it do you? They cause a lot of problems sometimes.
Old Jan 18, 2010 | 06:41 AM
1996f3507.3's Avatar
1996f3507.3
no leds but i do have a abs light that comes on as soon as i start to move forward.
Old Jan 18, 2010 | 06:45 AM
RRranch's Avatar
RRranch
I must have missed that. Did anyone suggest checking the rear wheel speed sensor and wiring? It's on the front of the rear axle. Erratic signals from it can cause the symptoms you describe too. I'd check and clean the connection on it first.
Old Jan 18, 2010 | 07:32 AM
yoslick's Avatar
yoslick
+1 and also remove the magnetic probe attached to it going into the pumpkin, might be sludged up with shavings/particles and need a good cleaning...
Old Jan 18, 2010 | 04:51 PM
1996f3507.3
thanks ill try cleaning the sensor and probe
96f350rcsrw460zf
Oct 27, 2005 07:10 PM
keke
Nov 14, 2004 07:33 AM
Gwilkrrs
Sep 8, 2002 11:20 AM
1949fordf3
Jun 19, 2002 02:27 AM
copeina
Aug 7, 2001 04:48 PM
