strange behavior
Old Jan 17, 2010 | 11:32 AM
1996f3507.3's Avatar
1996f3507.3
strange behavior
hey my truck is a 96 f350 7.3 when i am driving at about 60 mph the rpms jump back and forth from 1500 to 2000 is there something wrong?
Old Jan 17, 2010 | 11:36 AM
Talyn's Avatar
Talyn
its an automatic I take it?
Hit the OD button and see if it stops. =)
Old Jan 17, 2010 | 11:37 AM
drivembig's Avatar
drivembig
Can you actually feel the RPMs changing or is it just the RPM guage flucuating?
If you can actually feel it then it could be the speed sensor on the rear axle not giving correct info to the PCM, If it's only the RPM guage, then it could be the Cam Position Sensor as it controls the RPM guage.
I'm sure someone here will stear you in the right direction.
Old Jan 17, 2010 | 11:58 AM
1996f3507.3
it is a auto and yes i can feel it going back and forth. this is my first diesel so hopefully not a serious problem.
Old Jan 17, 2010 | 12:01 PM
1996f3507.3
it is a auto and i tried the od button but no difference adn i can feel the rpms jumping.
Old Jan 17, 2010 | 12:17 PM
pjwoolw's Avatar
pjwoolw
Welcome to FTE!
The throttle position sensor comes to mind. Just guessing. The speed sensor on the rear axle is a possibility too I suppose. The torque converter could be randomly locking and unlocking. Since its free pull the sensor on the rear end and clean it up.
Old Jan 17, 2010 | 01:07 PM
Talyn's Avatar
Talyn
if the OD button doesn't work, then its the TQ locking and unlocking.
Old Jan 17, 2010 | 03:05 PM
1996f3507.3
thanks for the suggestions, if its the torque converter would that be expensive to fix/
Old Jan 17, 2010 | 03:10 PM
drivembig's Avatar
drivembig
If your running 60mph at 2000 rpm, then it has to be a 4.10 rear end and if the torque converter wasn't locked then you would be running around 2500 at 60. When the torque converter unlocks then the rpm's will go up. Yours are going down. The only way that you could be going 60mph at 1500 rpm is if you had something like a 3.55 rear end, then if the torque converter unlocked it would be feasible to see 2000 rpm and back and forth. The torque is pretty expensive to repair.
What rear end do you have in your truck? If it's a 4.10 or even a 3.73, then I don't think it would be the torque converter locking and unlocking.
One way to tell is while your driving take your left foot and barely touch your brake while staying on the gas with your right foot and see if the rpm's go up....if they do then your torque converter just unlocked and when you took your foot off the brake it locked back.
Old Jan 17, 2010 | 03:16 PM
pjwoolw's Avatar
pjwoolw
You are still in the why stage. Keep it simple simple and check the cheap stuff first that might cause the issue. The torque locks and unlocks by command. If it were bad it would slip or just not function. Check your tranny fluid level too.
Old Jan 17, 2010 | 03:57 PM
MADVAN's Avatar
MADVAN
Being that you do not have a flashing od lamp
my money is on brake lamp/system failure.
Check all the brake lights first.
.02
Bill
Old Jan 17, 2010 | 04:02 PM
Hussler's Avatar
Hussler
.02
Bill
Live and learn .. Holly Cow, that fits the symptoms.
Tried to Rep but must spread it around first.
Old Jan 17, 2010 | 04:59 PM
Talyn's Avatar
Talyn
Hmm, that is an interesting though bill. I'll agree with that.
Old Jan 17, 2010 | 05:04 PM
TheTowingCowboy's Avatar
TheTowingCowboy
Just for information sake, are you talking about the switch that is used for the brake lights at the pedal? ANd are you saying that it is incorporated into the TC's electrical system and that it unlock the TC when your slowing down so a faulty switch would make it go in and out?
Old Jan 18, 2010 | 04:26 AM
drivembig's Avatar
drivembig
Yes a faulty brake switch on the pedal can make the TC lock and unlock.
