Exhaust stud removal
Old Jan 16, 2010 | 04:12 PM
drumfield's Avatar
drumfield
Little history first. 1985 F250, 460cid. Exhaust went bad, needed replacing. Original manifolds look like they haven't ever come off since day 1. Got the pipes removed, but still need to remove 2 studs for the ball & socket "doughnut" joint. No threads on them to repair, anymore. when I loosened the nuts, a cloud of rust fell (what remained of the threads). What, in your opinion, is the best way to get these out, without removing the manifolds? I'm on a very tight budget, and can't risk broken bolts in the head.
Old Jan 16, 2010 | 04:44 PM
Slip ford man's Avatar
Slip ford man
The answer is HEAT...you need a torch to get it hot enough, then clamp a pair of vise grip's on it before it cools too much. I would not attempt removel in any other way...good luck!
Old Jan 16, 2010 | 06:34 PM
drumfield's Avatar
drumfield
Heat the stud, or the manifold around it? (Good thing I power washed the motor recently)
Old Jan 17, 2010 | 02:16 AM
mark a.'s Avatar
mark a.
Heat the manifold.
Old Jan 17, 2010 | 03:50 AM
drumfield's Avatar
drumfield
Thanks, guys. Time to dig old "Victor J." out.
BKSMN
Sep 24, 2016 05:11 PM
jagrote
17
May 29, 2016 11:46 AM
balingwire
Exhaust Systems
Mar 25, 2009 11:36 AM
hink10
13
Jul 4, 2004 01:52 AM
canbman
Exhaust Systems
Nov 4, 2003 01:23 AM
