Remove and replace exhaust manifold studs?
Old Mar 23, 2009 | 07:55 PM
balingwire's Avatar
balingwire
How do I remove the existing exhaust manifold studs from a 351M/400 passenger side manifold without breaking the manifold, the studs, or messing something else up. The manifold is off the engine. Thanks.
Old Mar 25, 2009 | 11:36 AM
daveengelson's Avatar
daveengelson
In general, if having problem removing a stud usually let the stud/manifold set in penetrating oil for few hours. Thread 1 nut onto the stud as close to manifold and still have room to manuver. Then thread another nut and cinch the 2 against each other. I will put the thickest nut I can find, may require couple wrenches, or combination of ratchet/wrench and need the room for both. Then while holding the one, I use the other wrench and try and back out the stud, take small increments; loosen, tighten, etc. Another option may be an air ratchet where the torque would be directed from the center, seems may be less incline to snap than with side torque of wrench or ratchet, only not sure air ratchet would provide enough torque to loosen a seized stud. Being the impatient type, I would probably use an impact gun set on medium, certainly would have the torque but risky may end up damaging the manifold, perhaps best to take it slow and easy. Anyhow, food for thought!!.
lmarkie
Mar 23, 2017 07:07 AM
rkmaxwel
Exhaust Systems
May 1, 2016 10:05 AM
F350dog
Apr 2, 2015 09:55 AM
rustywheel68
Jan 9, 2011 04:03 PM
JOE SKI
1997 - 2003 F150
Apr 7, 2008 08:03 AM
