warm-up time
Old Jan 16, 2010 | 02:28 PM
embry1123's Avatar
embry1123
Thanks Tim, I'll go into the dealer this coming week and get the flash, does it also incorporate everything that was in the flashes previous to it or do they have to be done in sequence?. I've always been the guy that doesn't trust the dealer, so I stay away from them, except to buy parts. Guess I was doing myself (and my truck) a dis-service this whole time.
Old Jan 16, 2010 | 02:47 PM
D8chumley's Avatar
D8chumley
Resident smarta$$
I believe the latest will incorporate all previous flashes, but maybe someone will confirm this. At least you avoided the FICM killer flash! As far as doing your truck a dis-service, I don't think thats necessarily true. As long as it has been working for you, thats all that matters. Some report loss of performance and even more loss of mpg. Mine gets 13ish mpg tops, no matter what I do. I'm OK with a truck that weighs 8600 lbs getting that, though. The diagnostics and the upgrades for the codes/SES is worth it IMO. BTW the flash should only cost around $100 in case you're wondering.
Old Jan 16, 2010 | 04:12 PM
embry1123's Avatar
embry1123
I'm still getting around 14.5 around town and 17-18 on the road... Not sure if I want to chance the lower mpg's. But if the flash(s) address any of the runability problems I'm having, including cold start issues, then maybe it is worth it. As I read the flash info, it seems to also address sticking injectors? Not sure how software could do that, but maybe it can...
Old Jan 16, 2010 | 04:17 PM
D8chumley's Avatar
D8chumley
Resident smarta$$
I have 6.5" lift and I'm running 37" tires, so you'll probably do better than me The last few flashes, including the newest one heats the spools in the injectors so the oil flows easier until the fluids warms up.
Old Jan 16, 2010 | 04:20 PM
texans's Avatar
texans
it dose address sticking injectors. dose it cure the problem? sometimes yes sometimes no. but it sould at least make it alittle better. I just had the lasteset flashed installed in my truck a few weeks ago for $90. It didnt hurt my millage any I am like tim I get 13-15 tops no matter what I do, and I still get the same. Although I never really get a full tank of just hwy. I do a lot of mixed driving. So its hard to say what im getting on hwy untill the next long trip I take, but then again that is usally pulling 15k+ 5th wheel. even pulling that I still get like 11-12 mpg.
Old Jan 16, 2010 | 04:30 PM
embry1123's Avatar
embry1123
Thanks Scotty, I'll be in Dallas on Monday and I'll check into a dealer there to see if they can squeeze me in.
Old Jan 16, 2010 | 04:31 PM
foul1's Avatar
foul1
Ive been plugging mine in and I would say 10 mins tops the factory gauges are in the middle always didnt seem to matter if it was 10 below or ten above. I have been told I have two weak injectors when I had the ficm replaced a couple of months ago.
Old Jan 16, 2010 | 05:02 PM
bismic's Avatar
bismic
Originally Posted by embry1123
I just chnaged the oil and used 15-30 Rotella.
Did you mean 15W-30 or 15W-40? If it really is 15W-30, what is the API rating for it?
Old Jan 16, 2010 | 07:32 PM
texans's Avatar
texans
he meant 15w-40 mark. if you look at the post right after the one where I had the same question he corrected him self
packrat56
Mar 2, 2014 02:48 PM
packrat56
Mar 2, 2014 08:59 AM
the almighty schmuck
Jul 20, 2011 09:18 PM
motorsportluvr
May 14, 2006 05:00 PM
stroker"1"
Feb 25, 2005 06:33 AM
