Electrical Drain
Old Jan 19, 2010 | 09:13 PM
Dieselman929's Avatar
Dieselman929
And Cartmanea, thanks to you also!
Old Feb 10, 2010 | 05:34 AM
nt250xlt's Avatar
nt250xlt
I have a problam with battery draining in my2002 f250 xltwith 7.3and only 100k .The auto elec has just about pulled the whole vehicle apart but still no luck with finding where drain is happining. All plugs have been pulled of computers radio doors alternator abs under bonnet light and they are starting to talk about burning it not really but they are running out of ideas.Can anyone help with ideas as this is starting to get expensive.
Old Feb 10, 2010 | 06:39 AM
bismic's Avatar
bismic
They must have at least narrowed it down to a fuse ???
If they can't find it, do what cartmanea described (yourself). Sometimes you do not get thorough work from folks (I have been there on this exact situation).
Old Feb 10, 2010 | 07:58 AM
sflem849's Avatar
sflem849
Originally Posted by cartmanea
Use an ammeter and go through your fuse box. Pull each fuse, insert ammeter to check current through that circuit, repeat for all fuses. Do this with the engine off and after the door has been open long enough for the dome lights to go out.
Couldn't you do this with the fuses in? I think most fuses have a little opening where you can get a MM in.
Old Feb 10, 2010 | 09:56 AM
cartmanea's Avatar
cartmanea
The ammeter has to go in place of the fuse so the current flows through it. If you try measuring with the fuse in place the current will go through the fuse and not through the meter and it will not measure anything. Those points are for measuring voltage.
Old Feb 10, 2010 | 10:00 AM
sflem849's Avatar
sflem849
Makes sense to me, that is why I asked. I only know enough about electrical to be dangerous
Old Feb 10, 2010 | 10:02 AM
cartmanea's Avatar
cartmanea
Its always good to ask!
Old Feb 10, 2010 | 08:35 PM
nt250xlt's Avatar
nt250xlt
Battery draining
think they have found the problam it is the printed board that goes on the back of fuse box . ?
it is in the 15 fuse that they are saying is problam can this be right as new board is $1500 au bloody expencive
feo_nuts
29
Mar 28, 2014 12:43 PM
akamacgyver
Jul 25, 2012 05:49 PM
PastorTramp
May 30, 2011 08:37 AM
2horses
May 9, 2011 01:49 PM
