Modular V10 (6.8l)
New Transfer Case Shift Motor?
Old Jan 15, 2010 | 12:51 PM
tgr8st's Avatar
tgr8st
Hey guys,
I've been doing searches for the past couple hours and all the Ford forums I know of. Here's my problem:
4wd is not engaging at all. The dash light does not come on. The hubs still spin easily and even when manually locked, I cannot get 4wd to work. I checked the fuses and they are good.
I was under the truck and had my buddy turn the 4wd switch...there is no noise coming from the transfer case.
Through all the reading I've done, it sounds like I need a new transfer case shift motor. Does that sound right?
Old Jan 15, 2010 | 03:14 PM
Fordsflylow's Avatar
Fordsflylow
I bet you have a bad relay. Have you checked both fuse boxes, one under dash and one in engine compartment?
Old Jan 15, 2010 | 11:45 PM
tgr8st's Avatar
tgr8st
Both fuse panels were checked.
Where is the relay located??
Old Jan 15, 2010 | 11:47 PM
tgr8st's Avatar
tgr8st
searched and found it... I will check it out tomorrow. Thanks
deerediesel78
Jan 5, 2015 09:27 AM
Pigman54
Ford Truck Parts for Sale
Sep 13, 2014 11:38 PM
mtullis
May 10, 2013 10:28 PM
fe8u
Dec 29, 2012 01:14 AM
blk2000stang
Nov 22, 2005 09:06 AM
