steering box
Old Jan 15, 2010 | 11:20 AM
82ford302's Avatar
82ford302
steering box
i did some searches on converting to "real" power steering for my 76 F250 but i still have some questions.
1) will the 73-? power steering 2wd box bolt right on my frame with no mods? and does it matter if its from a f150, 250 or 350 ?
2) if the 2wd box does mount directly, do i just need an adjustable link going from the pitman arm to the steering knuckle?
thanks
Old Jan 15, 2010 | 12:01 PM
82ford302's Avatar
82ford302
what i want to do is put the skyjacker 4" lift kit on the truck as well as 39" tires. but the more i think about it, the pitman arm might be to close or might even hit the leaf pack. im at a lost for words on what to do at this point lol.
i looked and came up with this kit http://www.powersteeringpros.com/add...82-80019.html#
can this kit be peiced together from junkyard parts and what trucks would work?
Old Jan 15, 2010 | 01:00 PM
bucks77ford's Avatar
bucks77ford
There are a few different conversions for this, but without some sort of modification. Without getting into those conversion details, if you just want a bolt on deal and keep the simple drag link push/pull type setup, than what you see in the kit is what you need. You can pretty much piece together what you need at a junkyard and the only thing you really need from the kit is the mounting bracket for the gear box from what I can tell.
Old Jan 15, 2010 | 01:06 PM
73supercamper's Avatar
73supercamper
i can not find where to go to ask some questions about a 460 is thier a certain place to look on the site or know where i can get the help
Old Jan 15, 2010 | 01:41 PM
82ford302's Avatar
82ford302
thanks for the info Buck. what im really after is something that would take the less fab work to do. i dont mind fabbing my own stuff but i dont really like doing it lol. you know how that goes.
Old Jan 15, 2010 | 02:44 PM
82ford302's Avatar
82ford302
something that slipped my mind while asking questions is that i have a 79 f150 4x4 that is at a friends shop. could the box and related steering stuff be used off that truck as well?
quintin51
Sep 2, 2014 09:24 PM
MADFord4X4
13
Aug 4, 2010 01:24 AM
400Nut
Aug 30, 2006 09:37 PM
Jszbum
Mar 18, 2003 10:38 AM
kelsey
Dec 19, 2002 10:22 PM
