Fuel Injector Quality
Old Jan 14, 2010 | 11:54 PM
wantaford's Avatar
wantaford
Anyone have good/bad experiences with Accel Injectors?
I want to replace all of mine. Ford wants $92 each wholesale, AZ wants $70 each, I can get a set of 8 Accel brand from Summit (26 lb stockers) for $279. The Ford Racing 30 pounders are only $240 for a set of 8. What to do?
My other question is I know the stock Fuel pumps only supply up to the 24lb injectors capacity. If going to 30 lbs is it going to effect the driveability that much?
Old Jan 15, 2010 | 04:49 AM
EPNCSU2006's Avatar
EPNCSU2006
I would stick with the stock size to avoid any kind of tuning headache. Ford Racing should have 24 lb/hr injectors for about the same price as the 30s. Another option would be to have a look on ebay for reconditioned injectors.
Old Jan 15, 2010 | 04:50 AM
larrylass's Avatar
larrylass
i would go to www.fordfuelinjection.com and buy there FI rebuild kit for 25.00 bucks and clean and rebuild them. Lots of info on there how to
BigLar
Old Jan 15, 2010 | 11:16 AM
wantaford's Avatar
wantaford
Summit does not list Ford Racing injectors for 24lbs. I will have to check around. Anyone have good bad experiences with Accel injectors?
Jason
Old Jan 15, 2010 | 11:21 AM
Big-old-460's Avatar
Big-old-460
Ford 24lb injectors 88-97 EFI 460's is the ones i bought from Ford.. pretty penny Next time i will just rebuild them
jayson.
Old Jan 15, 2010 | 11:34 AM
lew52's Avatar
lew52
I would go with the FR injectors , if you want some real nice injectors go to Pro M racing , you can get a set of matched injectors that have been flow tested so they all flow the same . I think they start at about 280.00 for a set of eight...Lew
Old Jan 15, 2010 | 01:30 PM
Conanski's Avatar
Conanski
Do not use anything but 24lb injectors unless you get the EEC reprogrammed. I cannot vouch for this vendor but this is a pretty good price for a set..
Buy Ford Racing Parts - Ford Racing 24lb Fuel Injector Set
Old Jan 15, 2010 | 01:46 PM
wantaford's Avatar
wantaford
I know I would need a calibration / reflashing if I go with a bigger injector. However I don't think my stock fuel pumps would fully supply injectors bigger than 24 lbs anyway.
I have been needing a reflashing in a big way for over a year and just have not got around to doing it
GammaDriver
Feb 4, 2007 10:48 AM
hescbr600
May 16, 2006 08:33 PM
351M
Jul 19, 2005 10:08 PM
pinellas50
Sep 22, 2003 11:25 AM
