Very O/T but need help quick!!!
Old Jul 19, 2005 | 08:53 PM
351M's Avatar
351M
I have been working an a '90 Nissan 240 SX for awhile for somone now. It had 2 dead injectors so I had a set of 24lb/hr Accels sitting there. I threw them in, it runs but I just found out (forgot to check before) that the fuel PSI on this car is 34psi!!!! the stockers are like 270cc/min (about 27 or 28 lb) I know it was a bit lean but with that little pressure it is way too lean. Any idea how i would go about figuring what the rating should be to make up for this? I was thinking at least 36lb injectors. BTW Accels are rated 24lb/hr at 45psi same as the FMS injectors.
Old Jul 19, 2005 | 10:01 PM
Ford_Six's Avatar
Ford_Six
Is that the correct pressure stock, or is the regulator or fuel pump worn out? There's probably a ricer upgrade for the fuel pressure regulator, usually they're adjustable so you can crank up the pressure and run the 24's all the way across
Old Jul 19, 2005 | 10:08 PM
351M's Avatar
351M
Well, it looks to be 34psi stock. I was told to try a greddy emanage system. But for the price its cheaper to change injectors. I actually just happend by a conversion program online that says at 34psi a 30lb/hr will flow like 274cc/min (26lb/hr) While the 24s that are in it are like 207cc/min at that psi. So since the car needs 270c injectors I am either going to have to boost to like 49psi on the fuel system or go with the 30lb injectors.
1veryShort1
1997 - 2003 F150
Jun 6, 2014 02:11 AM
powerstroker100
May 21, 2014 08:18 PM
maddenusmc606
Modular V8 (4.6L, 5.4L)
Aug 7, 2005 12:07 PM
Bigmark'sblownv10
Modular V10 (6.8l)
Mar 27, 2005 04:16 PM
RiveraD123
Apr 4, 2004 08:01 PM
