CODE HELP
Old Jan 14, 2010 | 06:52 PM
Krisx125's Avatar
Krisx125
CODE HELP
Alright, i threw the truck on the scanner today quick. It threw 5 codes. I didnt write them down, but 4 were all glow plug related. Saying Bank #1 and #2 glow plugs were low voltage..and GPR fault low..i just replaced it with a standard GPR. It buzzes when i cycle the plugs. Makes the noise like the old fords when the doors open. Doesnt click like normal relays. Im going to take it off and return it and buy a GPR109 from napa. Other codes was low ICP sensor? Should i put the new GPR and ICP in the truck and scan it again? What are the symptoms of a faulty ICP?
Old Jan 14, 2010 | 08:25 PM
Hussler's Avatar
Hussler
With the codes you mentioned (GP) I assuming you have a Cali truck? If so you would have a special GPR (California style) with a bar type strap. You would have 5 small wires and two big cables instead of two small wires and two big cables. Which is it?
Here is the diagram on the cali GPR circuit ...
and here is the diagram on the federal GPR circuit ...
Old Jan 14, 2010 | 09:05 PM
Krisx125's Avatar
Krisx125
nope, i have the fed GPR set up. what made ya think i had the cali? I have two large wires and two small ones.
Old Jan 15, 2010 | 06:52 AM
Hussler's Avatar
Hussler
The codes you mentioned.
What scanner did you use?
Cali PCM monitors Bank glow plug voltage.
Federal PCM does not.
Old Jan 15, 2010 | 08:55 AM
Krisx125's Avatar
Krisx125
hmm, got me there..My GPR only had two big leads and two smaller ones.How else do i know if its a cali truck? Vin? It said it was made in the kentucky plant.
coreyallan01
Jan 6, 2015 10:36 AM
sammydiesel13
Jan 5, 2014 09:31 AM
JTS1975
Jun 29, 2011 10:20 AM
jermort
Dec 1, 2009 05:16 PM
PSNut
21
Feb 1, 2007 12:23 AM
