NOW IT WONT START
Old Jan 14, 2010 | 11:45 PM
  #31
FORDF250HDXLT's Avatar
FORDF250HDXLT
" ‘designed by American built by Chinese’ "
sadly,what isn't today it seems hey.
  #32
Rick Wallace's Avatar
Rick Wallace
Thanks Marianna,Your just down the road from me,If I go with the push button syst will I need the controller and the relay? Or just the relay?
Old Jan 15, 2010 | 08:52 AM
  #33
Fishin76's Avatar
Fishin76
Push button only needs the relay, a wire to the positive terminal or the starter relay, and one to gound, with the switch in the middle of the positive wire before the relay. the ground goes from the relay to a good Frame ground . Wiring it to the starter relay is so that you can't accidentally activate the GP's with the truck off and key out.
Old Jan 15, 2010 | 09:10 AM
  #34
Rick Wallace
Thanks,I think Ive got it in my head now!Im going out to test the relay
Old Jan 16, 2010 | 05:22 AM
  #35
Dave Sponaugle's Avatar
Dave Sponaugle
That relay is mounted down beside the voltage regulator behind the passenger side battery.
Purple wire needs power to activate the relay, I like to pull power off a fuse that is only hot when the key is on, run it to a momentary switch, then out and connect where the purple wire is now.
The current draw of the relay coil is small, so the wire can be 16 AWG from the fuse to momentary switch to relay.
Done wiring.
Now to operate, turn the key on, push momentary switch for 10 seconds, start engine.
With the usual temps you see in Florida, you probably won't need 10 seconds, you can adjust that time as you get used to the system.
Old Jan 16, 2010 | 11:57 PM
  #36
Rick Wallace
Thanks Dave,I tested the relay and I do belive its toast! The small ground across from the purple wire dosent have a wire looks like it never had one connected,ill solve that when I pick up a new one next week
Old Jan 17, 2010 | 07:42 AM
  #37
Dave Sponaugle
If there is no ground wire on there, it will not work.
Caution here.
The starter relay and glow plug relay look like each other with one exception.
Near both of the small terminals on the starter relay you will see a small S and I in the case, one by each small terminal.
The glow plug relay does not have those labels near the small terminals.
The starter relay grounds through the mounting screws, one end of the trigger coil is attached to the mounting plate, the other end to the small S terminal.
The glow plug relay grounds through the second small terminal, both small terminals are where the coil windings terminate.
Which wire goes on which terminal makes no difference, but they both must have wires on them.
If you have no wire on the second terminal, it is possible that someone used a starter relay to replace the glow plug relay, and moved the ground connection down to the mounting screws.
Old Jan 17, 2010 | 07:51 AM
  #38
Rick Wallace
AH-HA! When I got the truck the guy said he had a new relay put in it,it worked for me only for a few days,the light came on inside one morning and stayed on a long time,then has never worked since.Thats when a so-called mechanic I knew put new GPs and wired it direct to the battery.It looks Identical to the starter relay.Thanks! Im learning alot
Old Jan 17, 2010 | 08:17 AM
  #39
Rick Wallace
YEP, Its a starter relay Ill remedy that one day this week
Old Jan 17, 2010 | 08:44 AM
  #40
Dave Sponaugle
The starter relay can be used.
You just have to make sure the mounting screws are grounded and the purple wire is on the S terminal.
That plate where the glow plug relay is mounted is mounted on the plastic inner fender.
So the only way anything on it is grounded is through added ground wires.
Mine were in bad shape, last fall I ran new grounds to the voltage regulator, glow plug relay, low vacuum sensor and horn.
Now the horn works better, the batteries charge better and the glow plug relay works better.
Old Jan 17, 2010 | 08:52 AM
  #41
Rick Wallace
I think starter relays are cheaper than the others,I think ill reground everything while im doing
Old Jan 17, 2010 | 12:25 PM
  #42
Dave Sponaugle
NAPA has them both listed as the same price.
And it you don't know about checking for the small S and I, in parts books that look the same, even though the numbers are different.
So most people just assume they are the same part.
The only difference is how they ground the trigger coil.
After years of vibration and weather, with a fair amount of road salt in the winter, I replaced all my grounds and battery power to the glow plug relay, upgraded the alternator to glow plug relay power wire and reworked most of the wiring on the passenger side last fall.
I used the glow plug relay positive terminal as the power distribution point since it was closer to the battery.
Also cut out a lot of excess wire that Ford had used in an attemp to make the amp gauge work, which has never moved.
I find an after market volt gauge is of more use to me anyway, it gives a better indication of how much power is in the battery.
lalh20
30
Feb 19, 2014 07:14 PM
krogoski
Indiana Chapter
Feb 14, 2011 02:28 PM
lostman
137
Feb 19, 2010 06:13 AM
buck20
Dec 17, 2007 12:33 AM
GiS
24
Dec 20, 2005 06:13 PM
