292 y block gaskets
Old Jan 13, 2010 | 09:35 PM
robe's Avatar
robe
Trailering
292 y block gaskets
OK, I've got my 292 freshened with new rod and main bearings, new rings, pushrods, oil pump ready to bolt on, etc. My question is... I get conflicting stories about using a sealant with the gaskets. I'm most concerned about getting the head gasket right, some say spray with a copper gasket sealant others say dry. What is correct for installing the head gaskets, timing cover gasket, oil pan, and intake???? thanks for the help.
Old Jan 13, 2010 | 10:37 PM
Old_Crow's Avatar
Old_Crow
I'm old school. Copper Coat on the head gaskets. Non hardening Permatex on the timing cover and oil pan, with a dab of silicon at the corners. Same on the intake.
Old Jan 16, 2010 | 01:08 PM
robe's Avatar
robe
Trailering
Thanks, Old Crow. Can you explain more about the dab of silicon @ the corners? I assume you mean an automotive silicon gasket product??
Old Jan 16, 2010 | 07:12 PM
Old_Crow's Avatar
Old_Crow
On multiple piece gaskets, I always sort of bed the joint in a dab of silicone RTV. Helps hold it together during assembly and seals the joint.
Old Jan 16, 2010 | 07:56 PM
flipklos's Avatar
flipklos
Dont use copper sealant if you have a composition head gasket. Youll never get the dang thing off again.
Old Jan 17, 2010 | 04:09 AM
Old_Crow's Avatar
Old_Crow
If everything was done correctly inside the motor, the heads shouldn't have to come off again until we're dead and buried. :-)
72fordgts
Apr 27, 2015 03:15 PM
Gigemags05
Dec 21, 2014 10:31 AM
jwrussell
Jun 24, 2012 09:07 AM
Oppland
Feb 20, 2011 09:30 AM
dafalcon
Aerostar
Feb 17, 2007 08:46 PM
