351w Head gasket replacement... Sealant or no?
Old 12-19-2014, 06:29 PM
Gigemags05's Avatar
Gigemags05
Gigemags05 is offline
The chilton manual says to use head gasket sealant. From what I've read online it seems like most do not.
I have basic fel-pro gaskets if that matters. The gasket sealants I have are permatex high temp gasket sealant and permatex copper spray-a-gasket.
Advice much appreciated. Trying to get heads on tonight.
Old 12-19-2014, 06:34 PM
FordFETruck's Avatar
FordFETruck
FordFETruck is offline
Does the factory use a sealant on headgaskets? no.
Just make sure both sealing surfaces are completely grease/oil/lint free and clean.
Old 12-19-2014, 06:45 PM
Gigemags05's Avatar
Gigemags05
That's exactly what I've seen elsewhere and I trust you since you have been such a help to me.
I wonder why the chilton says to use sealant.
Old 12-19-2014, 06:47 PM
FordFETruck
Ask Chris (ctubutis) about sealant with head gaskets. He can tell you all about it! I've found some pretty misinformation in aftermarket service books.
Old 12-19-2014, 07:17 PM
Gigemags05's Avatar
Gigemags05
Alright... Another dumb question:
Do I use the supplied line with the arp headbolts?
Old 12-19-2014, 07:19 PM
FordFETruck
What do you mean? do you mean the thread lubricant the bolts come with? yes, that would be a good idea. Just make sure the bolt holes are extremely clean and have no fluid in the bottom of the pockets. Doesn't take a whole lot of grease. Make sure to put some on the bottom of the bolt heads too.
Old 12-19-2014, 07:23 PM
Gigemags05's Avatar
Gigemags05
Ok perfect.
Thanks!
Old 12-19-2014, 08:04 PM
FordFETruck
Anytime!
Old 12-19-2014, 08:07 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
Thanks, Matthew.
Here is what happens when one uses RTV on head gaskets (which only a clueless dumbphuque does):
Do you see the little bits of RTV poking out? Poking out of what, you may ask... from the holes through which anti freeze is supposed to flow(!).
I trust you can see a problem with anti freeze/coolant not flowing through the heads.
Any kind of gel- or goo-type of sealant is going to get squished into those passages when the heads are torqued down; the ONLY "gasket sealer" I have heard of that *might* be OK to use with head gaskets is that copper spray-on stuff but, even then, I wouldn't us it unless I had a specific reason to.
If you are using Fel Pro gaskets, I would follow their instructions....
Old 12-20-2014, 08:09 AM
tree medics's Avatar
tree medics
tree medics is offline
The books I have say to use a sealer if you have steel shim type gaskets and no sealer if you're using composite gaskets. The sealer they recommend is a copper sealant. I'm not sure if you can even get a steel gaskets any more.
Old 12-20-2014, 10:13 AM
ctubutis's Avatar
ctubutis
ctubutis is offline
Old 12-21-2014, 10:31 AM
tree medics
Originally Posted by ctubutis
Yes that explains it better than my post thanks , Ctubutis.
ben73058
59
07-24-2020 07:17 PM
skidoorulz
03-31-2015 03:29 PM
fromm
04-14-2010 09:05 PM
ford_man
01-16-2007 01:50 AM
niteowl
04-21-2004 01:56 AM
Quick Reply: 351w Head gasket replacement... Sealant or no?
