Heading to the dyno
Old Jan 12, 2010 | 04:53 PM
kupaa's Avatar
kupaa
Heading to the dyno
OK guys, Jan 30 my friend rented the dyno for half a day.Any tips for me...
What gear to be in...
Old Jan 12, 2010 | 04:55 PM
robinsonpowerstroke's Avatar
robinsonpowerstroke
Give it hell!!!
Old Jan 12, 2010 | 05:04 PM
kupaa's Avatar
kupaa
Shooting for 300 hp
Old Jan 12, 2010 | 05:06 PM
robinsonpowerstroke
You should be able to hit that. Do you have a torque goal?
Old Jan 12, 2010 | 05:15 PM
kupaa's Avatar
kupaa
650-700 tq sounds good
Old Jan 12, 2010 | 06:44 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
id say 315/635
and start with the highest tune , on the worm engine, do it twice, than fiddle with other tunes. make sure the engine is up to full operating temp.
and good luck. its fun, belive me.
Old Jan 12, 2010 | 06:49 PM
Bigcat350's Avatar
Bigcat350
Highest tune and pedal to the floor. Also don't use your brakes on the dyno let them slow you down with there brakes. Have Fun its a Blast.
Old Jan 12, 2010 | 07:08 PM
kupaa's Avatar
kupaa
i only have 3 pulls,so start with the highest first? also what gear 3rd or od
Old Jan 12, 2010 | 07:25 PM
PETE'S_6.0PSD
if i were you i would not waist time on low tunes . go all out
do one pull with o/d on, and one with it off. now third pull with next setting down - do it with whatever o/d combo give you better# . and you all set.
o/d on off varies dyno to dyno.
id say with od on you should be able to load down the engine better.
see for yourself.
all trucks are like woman, all the same gender , but like diferent handling
see what yours like.
Old Jan 12, 2010 | 07:26 PM
CSIPSD's Avatar
CSIPSD
3rd, it will drop out of OD unless you have jodys dyno tune...
Old Jan 12, 2010 | 08:40 PM
kupaa's Avatar
kupaa
why will downshift to 3rd?
Old Jan 12, 2010 | 08:51 PM
Izzy351's Avatar
Izzy351
It thinks you're trying to pass someone.
Old Jan 12, 2010 | 10:33 PM
kupaa's Avatar
kupaa
is my injectors maxed out of fuel on Jodys 140hp tune or is there more?
Old Jan 13, 2010 | 12:12 AM
spunks00's Avatar
spunks00
i thought you want to run dyno in 1:1...so 3rd four you auto guys? and 4th for us 6spd guys
Old Jan 13, 2010 | 05:16 PM
PETE'S_6.0PSD
your injectors might be fine but your HPOP might not be able to keep up with oil demand.
