Heading to the dyno
Old Jan 13, 2010 | 05:37 PM
kupaa's Avatar
kupaa
yep forgot about the old HPOP
Old Jan 13, 2010 | 09:23 PM
Orezona's Avatar
Orezona
Your 02 HPOP is not old. If you have a way to monitor ICP during your runs you will probably see the 140 tune go flat or most likely fall. Not anything new. If it does the latter, don't hate your HPOP. Your stock HPOP is not known to keep up with 1xx performance tunes. Mine wouldn't keep up with 80e.
Old Jan 13, 2010 | 11:15 PM
jhand124's Avatar
jhand124
Originally Posted by kupaa
OK guys, Jan 30 my friend rented the dyno for half a day.Any tips for me...
What gear to be in...
I have another run set for the 28th and I would say go for it, high tune 1st.
Originally Posted by PETE'S_6.0PSD
your injectors might be fine but your HPOP might not be able to keep up with oil demand.
Ditto, the stock HPOP will not keep up with any tune on stock sticks.
Good luck...I think you should be able to put down at least 600 tq/300 hp.
Old Jan 14, 2010 | 04:30 AM
farmb0y's Avatar
farmb0y
Originally Posted by CSIPSD
3rd, it will drop out of OD unless you have jodys dyno tune...
I've dyno'ed a couple of times, and both times were run in OD/4th gear. The guys operating the dyno ran the truck and she never dropped down to 3rd. I'd talk to the guys running the dyno, they have probably done this once or twice before and would know best.
I would have liked to watch some of the gauges to see what was going on, but it was probably more fun to stand back and watch the truck perform.
Good luck with it, it's a lot of fun. I dyno'ed at 325hp/736tq with crappy single shot injectors and TW's tunes, most everything else was "stock".
Old Jan 31, 2010 | 10:19 AM
kupaa's Avatar
kupaa
OK did the dyno thing yesterday
1st pull was stock(forgot numbers)
2nd pull 140 tune 292 hp 539 tq
3rd pull 80 econ 288 hp 556 tq dont know why i have more tq in the lower tune
I was hopeing to be in the 3 bill catagory,it's a little shy of it but a least i put down more then a 12v cummins w 90 hp injectors.....
Old Jan 31, 2010 | 12:26 PM
Izzy351's Avatar
Izzy351
What happened?? To be honest, those numbers kind of suck. Mine rolled 311/681 on 120R, and 290/600 on 80E with very similar mods to yours at the time. What kind of dyno and what gear did you use? Mine was run with OD on -- I just looked, and I thought it was 3rd, but it was indeed in OD.
Old Jan 31, 2010 | 01:10 PM
kupaa's Avatar
kupaa
Yah Joe it does suck.I was driving my own truck left it out of OD spun her up to about 50MPH till the converter locked and nailed to red line. BTW it was a dyno jet.
Old Jan 31, 2010 | 02:16 PM
farmb0y's Avatar
farmb0y
Probably could have gotten a little over 300 if you ran it in overdrive, loaded the engine more. I don't know one way or the other.
I'm glad the guys running the dyno ran the trucks also when I did my runs.
Old Jan 31, 2010 | 02:46 PM
Izzy351's Avatar
Izzy351
What Adam said. You probably are in the 300s, just didn't get a good load on the dyno. Here's what my three runs looked like (80E, 120R, 140A):
Old Feb 2, 2010 | 08:45 PM
kupaa's Avatar
kupaa
Here's the graph....
IMG_0307.JPG 140 extream
IMG_0308.JPG 80 Econ
JBradley500
Oct 22, 2010 11:30 AM
tjc transport
New Jersey Chapter
Feb 27, 2007 05:10 PM
mattri
Colorado Chapter
Oct 25, 2004 05:10 PM
ford390gashog
Aug 22, 2004 12:22 AM
