Timing issues...distributor advance?
Old Jan 14, 2010 | 09:56 PM
  #31
EZFEED's Avatar
EZFEED
OK...hold up. I presume you installed a roller timing set correct? Did you dial your cam in? Did you set it like the pic I have in the engine below with the dowel and key on the crank aligned as such?
Old Jan 15, 2010 | 12:06 AM
  #32
jfaber's Avatar
jfaber
I was going to ask that same question! I just put a 460 together and the three keyway set I had had 2 keyways for retard and the one marked "advance" was actually the straight up keyway.
Old Jan 15, 2010 | 08:03 AM
  #33
Big Red 78's Avatar
Big Red 78
I used an edelbrock cam 2172, and the edelbrock timing gears and chain 7821. I put it in straight up. Lined up the dots on the gears. I just thought I should see mechanical advance sooner than 1800 rpms?
Filko
Nov 7, 2014 09:52 PM
Snakebeanz
19
Jun 1, 2014 04:32 PM
walkee
37
Feb 21, 2013 04:14 PM
bigjonv
Nov 25, 2012 12:36 PM
HangGlider
Jun 7, 2007 07:49 AM
