Fresh Rebuild Problems
Old May 26, 2014 | 11:59 AM
Snakebeanz's Avatar
Snakebeanz
Cool Fresh Rebuild Problems
Hello everybody Im new to the forum and am looking for some advice. First a little background on the truck. I am rebuilding a 66 f100 with a 352 bored 30 over. Had a valve job done, put Comp Cams 268h camshaft new timing chain hydraulic lifters and new push rods. The crank was turned and all new bearnings put in for cam and crank. New oil pump new fuel pump. I added a edelbrock performer intake and 600 carb. Also headers and dual exhaust. Now ive got the truck running but have white smoke coming from drivers side exhaust and plugs are getting black and wet. I have about 125 to 130 compression on all cylinders. Vacuum is running at idle about 11inches and wants to go up and down about an inch or so. If I advance timing way advanced to 30 or so btdc smoke seems to go away and plugs dry out???!!! Also vacuum hovers at about 16 or 17. Am I doing something wrong? This is my first rebuild so Im not sure what to do from here. Any help would be greatly appreciated. Thanks
Old May 26, 2014 | 01:46 PM
1972RedNeck's Avatar
1972RedNeck
Vacuum time it. I bet your balancer slipped.
Old May 26, 2014 | 03:07 PM
Snakebeanz's Avatar
Snakebeanz
I put a new balancer on put no1 at tdc and the marker was dead on.
Old May 26, 2014 | 05:58 PM
Snakebeanz's Avatar
Snakebeanz
Could this just be that rings need to have some time to seat???? I havent really driven it around much just through the neighborhood a few miles
Old May 27, 2014 | 11:54 AM
Snakebeanz's Avatar
Snakebeanz
Anybody have any other thoughts on this. Possibly a carb or intake issue???
Old May 27, 2014 | 03:01 PM
SuperSabre's Avatar
SuperSabre
I consulted my FE engine diagnostic book, and two possibilities show up - blowby caused by a clogged or malfunctioning PCV system - or a blown or incorrectly installed cylinder head gasket. Even though your engine is newly rebuilt, mistakes in the process have been known to happen. Head gasket installation is a particularly notorious one. Good luck.
Old May 27, 2014 | 10:06 PM
1964FORDTUF's Avatar
1964FORDTUF
White smoke (steady, like a crop duster) is typically a sign of anti-freeze burning in the exhaust. Smell the exhaust (carefully). Does it have sort of a sweet smell? Check your levels...coolant and oil, and also the color of both. I hate to say it but it does sound like head gasket. Why the smoke clears when you advance timing is a bit odd....
Old May 28, 2014 | 01:21 AM
TxStang2010's Avatar
TxStang2010
When the valve job was done was the head pressure checked for cracks ? if they were then I would lean towards a head gasket problem on that bank . Pressure check the cooling system on the engine after it has warmed up to operating temp ..... Just be very careful removing the radiator cap . if you lose pressure .... pull that head .
Old May 28, 2014 | 04:42 AM
Snakebeanz's Avatar
Snakebeanz
Thanks for the input. I had no idea a pcv valve could make such a difference. I just picked one off the shelf that looked right. I'll switch that out first to see if it helps. Also as far as a head gasket wouldn't that show up in a compression test?
Old May 28, 2014 | 04:45 AM
Snakebeanz's Avatar
Snakebeanz
I couldn't tell whether I had anything in th oil or not because of the break in additive I have done a fresh oil change and looks like clean oil so far
Old May 28, 2014 | 06:41 PM
Snakebeanz's Avatar
Snakebeanz
well I replaced pcv valve. and it made no change. tested pressure of cooling system and it seems to have a slow leak. driver side exhaust blows smoke and is moist. black residue when I put my finger inside exhaust also what looked to be like oil??? Next I pulled the header and all cylinders are clear on that side accept #7 which was wet black and sticky. I guess I have to tear the top end and replace the head gasket. Looks like I'll have a good Friday afternoon. Gotta order gaskets
Old May 29, 2014 | 06:56 AM
1964FORDTUF
"Black Residue" -- not sure but this could just be a rich mixture. You said cooling system "seems" to have a slow leak. If it does and you don't see anti-freeze leaking externally, sure sounds like issue with head gasket or head at cyl #7. When you had the valve job done, did they mill or deck the head at all? Did they check for hairline cracks between valves? There are valve jobs and then there are valve jobs...just saying.
Old May 29, 2014 | 11:44 AM
MNTBUGGY's Avatar
MNTBUGGY
Agree with 1964fordtuf
Did they replace the valve guides? If so they might not have gotten the fit correct and water could be leaking around them? or cracked the head. Have the head pressure checked or mag checked for cracks before you put it back on. Good luck
Old May 29, 2014 | 05:39 PM
Snakebeanz's Avatar
Snakebeanz
I don't know if the head was checked for hairlines. I was lind of ignorant to the whole process as this is my first build. I guess I will have to call and find out. Here is the list of what he says was done.
1. Disassemble and qualify parts 2. Glass bead and clean
3. Valve job- competion 4. New valve seals
4. Surface heads
5. Assemble and blueprint springs
So I guessing no it was not checked????
Also as far as a rich mixture I have tried to set the mixture a number of times to see if it would make any difference with no results. That had entered my mind could there be an issue with my carb?
Old May 29, 2014 | 10:42 PM
1964FORDTUF
4. Surface heads
Its somewhat difficult to diagnose without seeing the smoke you are talking about.-- Item 4 says the heads were resurfaced. I have seen sometimes when heads are re-surfaced but the block is not checked for true as well, a head gasket may not seat properly. I've also seen heads resurfaced and the head bolts not tightening all the way during re-assembly because they are now too long after re-surfacing (probably not your issue just stating many things can go wrong). My suggestion would be to play it safe and pull that head back off and have it checked over for a hairline crack between the intake and exhaust ports on #7. Keep us posted, send me a PM with your phone # if you want and I can call you tomorrow to try more diagnostics over the phone.
