Timing issues...distributor advance?
Old Jan 11, 2010 | 06:16 PM
Big Red 78's Avatar
Big Red 78
OK guys, I've been lurking for a while and searched without any real direction so here goes. I have a 1978 Ford F250 with the 351M and a 4 speed. I have been doing some upgrades and cannot eliminate my timing issues. So far I have replace the stock cam and lifters with an Edelbrock performer cam lifters and timing chain set. A performer intake and Edelbrock carb. I have a rebuilt distributor and a new module. new fuel pump and all the basic tune up items. I cannot get this thing to stop backfiring either through the carb or exhaust. I cannot run any vacuum advance due to this. If I disconnect the advance it runs Ok but misses a little on initial acceleration. Then it runs OK at best unless you floor it and then it runs like a race car! Can anybody give me some direction?
Old Jan 11, 2010 | 06:40 PM
1974F-100's Avatar
1974F-100
Just a thought... maybe the wires are one space off, not letting you get/remove enough timing? Happened to me several times, I had to rotate all the wires in the direction that I couldn't turn it far enough.
I hope you get it going.
Old Jan 11, 2010 | 07:24 PM
ranger429's Avatar
ranger429
Set the crank to TDC, check to make sure you have #1 wire on the correct spot on the cap where the rotor is pointing.
Old Jan 11, 2010 | 09:09 PM
Big Red 78's Avatar
Big Red 78
I don't think thats the problem. I can move the timing way advanced or retarded. It just has that miss right when you crack the throttle. but only under load. If I hook up the vacuum advance it backfires immediately when you accelerate under load. When you disconnect the vacuum its not near as bad. Coould the new cam have a different rate of advancement needed to run correctly. I saw one vendor here stating that factory distributors are EGR friendly and do not advance properly when EGR parts are removed or modifications are made to the valvetrain.
Old Jan 11, 2010 | 09:21 PM
79FordBlake's Avatar
79FordBlake
Distributer needs to be re-curved?
Old Jan 11, 2010 | 09:54 PM
Big Red 78's Avatar
Big Red 78
I think you are right about the recurve. How is this done? Another thought is can i replace the dist. with one from an earlier year engine to get a "pre" EGR curve? More interested in how to recurve the distributor.
Old Jan 11, 2010 | 10:02 PM
79FordBlake
Never done it before, but I need to do it on the dizzy for my 79 Bronco. There is a kit available and I think you just change out the springs on the mechanical advance. Maybe somebody has done it and will know specifics.
Old Jan 11, 2010 | 10:20 PM
1974F-100's Avatar
1974F-100
Does your dist. have a mag pickup? My last one was not stock but had a bad mag pick up, it did a similar thing yours is doing, I may have had the gap wrong also? I just switched it for a GM style HEI and it has been good since. Just thinking out loud hoping you get it.
Old Jan 11, 2010 | 10:26 PM
Big Red 78's Avatar
Big Red 78
distributor is the second "new" rebuilt unit I've had. I think we are in the right ballpark with the recurve. I read a little about how this is done but can i get this recurve kit at a auto zone or another local parts store? I'm willing to try this.
Old Jan 11, 2010 | 11:15 PM
montana_highboy's Avatar
montana_highboy
Duraspark_distributor_recurve_instructions_index
Old Jan 12, 2010 | 07:26 AM
Furyus1's Avatar
Furyus1
On my 400, I installed a distributor for a 460 - it seems to be curved differently than the 400 distributor and helped a lot with my pinging issues... Since the 351M and 400 are the same block, maybe this will help...
Old Jan 12, 2010 | 09:05 AM
Big Red 78's Avatar
Big Red 78
I think I will try the recurve. It can't hurt to try.
Old Jan 12, 2010 | 01:07 PM
Big Red 78's Avatar
Big Red 78
OK, I got the recurve kit ordered. Now can somebody who has some experience with an Edelbrock performer cam 2172, tell me what they used for initial timing? Cam card says 10-14 degrees. Is this pretty much where I need to be? Also, what will be my target total centrifical advance once i get the recurve kit? I know all engines are different but I just need a ballpark or somebody who has experience with these engines and know what kind of timing they like. I'm assuming from research I want this at full centrifical by 3000 rpm's?
Old Jan 12, 2010 | 03:38 PM
1977 HIGHBOY's Avatar
1977 HIGHBOY
Well i for sure am not an expert on the recurving. Just that i also had a lot of issues with the distributor in my 400 and after different issues here and there i just switched over to and HEI dizzy and what a world of difference elimiates all the little things that usually drive a guy mad. LOL truck ran like a champ ever since.
Old Jan 12, 2010 | 06:26 PM
dw_wanno's Avatar
dw_wanno
When you re-connect the vacuum advance hose to the carb with the engine running, does the vacuum advance pull all the way at idle? Not sure on the V-8s but this was the case on my I-6 and found out that I was missing an inline vacuum restrictor pod. Or possibly that the vacuum advance should be hooked up to a delayed vacuum port on the carb. Just an idea to try.
