Modular V10 (6.8l)
Need input (supercharger project)
Old Jan 13, 2010 | 04:24 PM
Boostcrazy99's Avatar
Boostcrazy99
Originally Posted by Krewat
Is that the Lightning intercooler I see on the floor behind the engine in the last pic? How you gonna handle that?
That's the belt guard on my air compressor, lol. The lightning uses a water to air intercooler. I will mount the factory lightning heat exchanger in the front bumper (plan to anyways). I will know more once I get my hands on one.
Old Jan 13, 2010 | 06:49 PM
reddogracing's Avatar
reddogracing
sounds like a great idea. Are you going to leave everything else the same, IE injectors mostly. This sounds like my kinda project.
I can not see the pics. or find them in your albums.
I understand making them fit the 10 cyclinders, but how are you going to do that and maintain the the same size on top? Just cutting 2 8's in half and making 10, would leave you with a longer upper surface as well, I have not figured that part out not being able to see those pics.
Old Jan 13, 2010 | 07:55 PM
Boostcrazy99
I will run the stock 42 lb/hr lightning injectors for now. I only have one intake right now and working on getting the second one. I will just make a plate to sandwich between the modified lower and the intercooler mid plate. This plate will have the proper opening for the lightning supercharger.
Old Jan 14, 2010 | 06:14 AM
reddogracing
If I follow you, you are going to make an adaptor? If so, why not make an adaptor for lighting charger to v10 lower? Could save work, and make money. Maybe I am still not catching your idea. Stupid gov pc will not let me look at photobucket.
Old Jan 14, 2010 | 06:47 AM
Boostcrazy99
The factory V10 lower does not have room for a intercooler. That's why I'm using the lightning lower to use the factory air to water intercooler.
Old Jan 14, 2010 | 08:12 AM
Boostcrazy99
Fabing stuff up is nothing new to me. I took a Eaton M90 supercharger off of a Thunderbird Supercoupe and put it on my 1991 5.0 bronco. It was intercooled and everything. He's a picture i dug up of it.
Old Jan 14, 2010 | 05:28 PM
reddogracing
Got it now!! TY. thanks alot, now I have to get the yard to buy some scrap lightings so I can try this! Hopefully you will get yours done before long, save the rest of us a lot of headaches LOL..
Old Jan 15, 2010 | 08:15 AM
Boostcrazy99
Trying to seal the deal on everything I need. Hope to have more info and pics for you guys soon.
Old Jan 15, 2010 | 06:29 PM
reddogracing
are the fronts the same between the 10 and 8? So you can use all the lightning brackets and pulleys?
Old Jan 15, 2010 | 06:43 PM
meanv10's Avatar
meanv10
Originally Posted by Johnny Langton
This is actually a good read on that piston type:
Hypereutectic piston - Wikipedia, the free encyclopedia
JL
It means what i thought. the eutectic point is .8% carbon in steel so hyper means more than .8 hypo means less. and more than .55% carbon in steel makes it a high carbon metal.
Its a little surprising that it doesn't become to brittle after forging with all that carbon, but those things could withstand some serious forces.
Old Jan 16, 2010 | 12:25 AM
Boostcrazy99
The front timing chain covers are the same but I think the lightning accessories drive is a 6 rib. Not a big deal as you can simple run a 6 rib crank pulley and belt on the 8 rib pulleys. I will have everything in a week so I can take pictures for everyone.
Old Jan 22, 2010 | 11:10 AM
Boostcrazy99
Got the belt drive parts in. Here are a few pictures.
Old Jan 22, 2010 | 01:34 PM
  #28
Monster-4's Avatar
Monster-4
Subscribing. Looking intresting.
Old Jan 22, 2010 | 06:26 PM
  #29
Team Violence's Avatar
Team Violence
Has anyone tried a side mount blower? In that an eaton M112 is mounted to a bracket ont he side of the engine... Audi guys do this to thier A4s with 2.8L V6s as it has no room on top of the engine. They just line it up with the other pulleys, fab a tensioner plate that has two tensioners and they run a longer belt.
Old Jan 22, 2010 | 07:10 PM
  #30
Boostcrazy99
Sure you can do this but the M112 has a huge discharge opening. The amount of fab work to create an outlet from the blower to the intercooler/throttle body would be tricky. I'm shooting for using mostly factory ford parts aside from the cut up factory intake and custom fuel rails.
