Steering wheel play/slop
Old Jan 11, 2010 | 06:56 AM
xc600's Avatar
xc600
I just purchased a used 2005 Expedition 4x4 w/67,000 miles. I've noticed a small amount of free play in the steering at speed. You don't notice it as much at a stop, but it's there. You can really feel it at 75mph with a side wind on the highway. It actually affects how you have to drive. I'm only talking about 1/4 or 5/8" but it's enough to change how you drive.
Do these trucks have rack in pinions or steering boxes on them. I haven't been under it to exactly look at it, other than the inspection at the dealer I did for leaks.
I've had dealings with older cars and bad steering boxes, and that is what this feels like, although not as bad as my old Cougar, it had about 3" of free play.
Any help or ideas on what I should look at or address to the dealer would be great.
Thanks,
Alan
Old Jan 11, 2010 | 07:10 AM
pablocruz69's Avatar
pablocruz69
I have a 97 Expy, I have a steering box on mine. I had it replaced about 4 years ago, because of a similar issue. I also had all the shocks replaced and seemed to help a lot with the handling and play in the steering. Good luck
Old Jan 11, 2010 | 07:49 AM
xc600's Avatar
xc600
Steering
If I'm not mistaken this truck has a rack in pinion. The play feels like it would be between the wheel and the rack and not from the rack to the rotors.
I suppose it could be inner tie rods, but it feels just like a bad steering box feels.
Old Jan 11, 2010 | 12:56 PM
benningstspeed1.0's Avatar
benningstspeed1.0
THERE ARE U-JOINTS IN THE STEERING SHAFT
Old Jan 11, 2010 | 08:05 PM
xc600's Avatar
xc600
After review
Well, after further review I've determined that the play is coming from inside the rack. I'm assuming it's wear. I guess I'll have to live with it until I decide to either have the rack rebuilt or swap it out for a new one. I doubt that the dealer I bought the truck from is going to do anything for me, and I'm pretty sure you can't adjust a rack like you can a steering box.
Thanks for the help.
Alan
Old Jan 12, 2010 | 09:52 AM
dirtmonkey11's Avatar
dirtmonkey11
There could be a couple different things causing your problem. The first thing I would look at would be the ball joints and tie rod ends. If those check out then I would also check the steering shaft, I have replaced some in different types of trucks that had similar problems to what you are saying. If that is ok also then I would check the steering box to see if it in good condition. Those would be the main things that would cause the symptoms that you are explaining.
Old Jan 12, 2010 | 09:59 AM
xc600's Avatar
xc600
Sorry
As noted above, this truck has rack in pinion steering. No steering box and related steering links.
The play is in the rack, with no movement seen on either end of the rack when the play in the steering wheel is being moved.
Old Jan 12, 2010 | 04:18 PM
pdqford's Avatar
pdqford
Originally Posted by xc600
I doubt that the dealer I bought the truck from is going to do anything for me, ..........Alan
Well, ya never know until you ask
Old Jan 12, 2010 | 04:23 PM
emtzach's Avatar
emtzach
there is also a bolt from the steering colum to the steering input shaft the bolt tightens down on a slip sleeve. this is at the floor board covered by a plastic trim, just make sure its tight as well along with the rack and pinion
mfhull
May 4, 2021 10:43 AM
skyking897
Apr 20, 2017 11:40 AM
64rednwhite
Mar 10, 2017 08:58 PM
AKHunter93
21
Aug 19, 2016 01:10 AM
swolh
Sep 15, 2015 12:45 PM
